Are wide speed humps high enough to cause damage?
Discussion in 'Gen 4 Prius Main Forum' started by EnergyCar, Oct 1, 2023.
  1. EnergyCar
    EnergyCar New Member
    17
    Havertown PA
    2021 Prius
    L Eco
    I recently drove over a speed hump at about 5mph and made a slight turn to the left as I touched the hump. I thought I heard a scrapping sound. When I got home I went underneath the car with my flash light and didn’t see anything bad other than the normal wear and tear. I almost drove back to the location to see if it was possible for the undercarriage to hit the speed bump. Instead, I’m planning to just have a mechanic take a look and see if there is any damage. Has anyone had a similar experience?
  2. Pulse07
    Pulse07 Active Member
    273
    139
    East Bay, California
    2020 Prius
    XLE AWD-e
    Other then scrapping, there's nothing you need to worry about. The bottom is covered with plastic for aerodynamic, even so, the plastic gets scratched. The sound you hear is probably the suspension dropping down (you said you made a left on the speed bump, in my head I imagine one wheel on the speed bump and other on the street)
  3. Pulse07
    273
    139
    2020 Prius
    XLE AWD-e
    51,155
    it could just be the very front plastic scraped. i get the a lot at parking curbs and sidewalks
  5. EnergyCar
    17
    Havertown PA
    2021 Prius
    L Eco
    I see. Though I think I made my turn after both wheels made contact with the speed bump. However if it were one wheel on the speed bump and one wheel on the street, would be enough for the undercarriage to make contact with the bump?
    I feel like going out there to re-create it however, I’m afraid that I actually might hit the bump if I didn’t already. lol
  6. EnergyCar
    17
    Havertown PA
    2021 Prius
    L Eco
    I’m going to check the front and see if it was indeed that area that was affected. I’ll update you.
  7. Doug McC
    Doug McC Senior Member
    1,044
    396
    Midwest
    2022 Prius
    There are a couple of speed bumps near us that are higher than normal and longer (as compared to “wider” being across the road) and I can scrape with my ‘22 Nightshade Edition at any speed over a crawl.
  8. Drakxyfly
    Drakxyfly Member
    119
    26
    Usa
    2021 Prius
    I'm lowered on RSR springs i can slightly scrape the rear plastic that hangs down by the rear wheels going into my garage if I don't pull in on an angle.
  9. EnergyCar
    17
    Havertown PA
    2021 Prius
    L Eco
    @bisco
    Update: There are scrapes on the plastic firewall underneath at the front of the car, however I’m not sure if it was caused by the previous owner. I’m adding a photo. Also, I had the following work completed:
    • Suspension (damage / leaks / worn components)
    • Axle hub & bearings (damage / leaks / noise)
    • Drive / CV shaft (damage / leaks / boots)
    • Propeller / driveshaft (damage / leaks / U-joints)
      They said everything looked intact, no leaks, breaks or cracks, etc. so far as they could tell, everything was in tip top shape. Now, I’m dealing with a bigger issue I posted in the Care and Maintenance forum.
    • Thanks.
