Are winter tires in NYC worth it?
Discussion in 'Prius v Accessories and Modifications' started by woppa, Jun 5, 2013.
  1. woppa
    woppa Junior Member
    60
    NYC
    2013 Prius v wagon
    The title says it all. I'm not sure whether or not I should pick up a set of winter tires. Living in NYC we do get the occasional bad snowstorm but if I had to guess there is probably snow on the ground only for ten or twelve days out of the year. Is it worth the 800 bucks for xi3s mounted on their own set of steel rims? Then I have to deal with the damn tpms thing, which if I can't fix myself I will probably ignore the light for 4 months out of the year. Any advice is appreciated.
  2. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,997
    Fort Lee, NJ
    I went through many NYC winter with my previous 2006 Prius (now PiP) with all-season tires. The roads get plowed quickly so there was no need for snow tires, at least for me.
    woppa likes this.
  3. jdenenberg
    jdenenberg EE Professor
    3,852
    1,852
    Trumbull, CT
    2020 Prius
    LE AWD-e
    All season tires should be good enough for NYC, especially the Nokian WRg2 which can match many winter tires for snow/ice traction. They are also LRR rated and will improve your MPG.
    JeffD
    woppa likes this.
  4. stevemcelroy
    stevemcelroy Active Member
    873
    194
    Boulder, CO
    I would not bother with snow tires in NYC - I never had them all of the years that I lived in Boston. I guess the one exception would be if you happen to need to drive in a really hilly area or have a long and steep driveway and need the traction.
    woppa likes this.
  5. syscon
    syscon Member
    329
    42
    Edm. Alberta
    You don't need winter tires in NYC; I don't have them in Alberta where winter is 8-months out of 12 :)
    I'll use Tire Traction Aid in worse case scenario (but I never had to yet); Prius handle much better in winter than my old RWD Volvo.
    Motomaster Tire Traction Aid | Canadian Tire
    woppa likes this.
  6. Air_Boss
    Air_Boss Senior Member
    3,952
    1,083
    New Yawk
    Depends on whether you venture out of Manhattan, especially northwest to northeast where the snow tends to be heavier and slower to be removed.
    woppa likes this.
  7. woppa
    woppa Junior Member
    60
    NYC
    2013 Prius v wagon
    I live in the bronx, I probably should change that because most non new yorkers think nyc is strictly manhattan.
  8. RRxing
    RRxing Senior Member
    2,520
    1,791
    NEPA
    I have never felt the need for snow tires. If it snows bad enough, I'll take my wife's Explorer to work or stay home... :)
    woppa likes this.
  9. Absolutly Red Hot
    155
    83
    91
    SoCal
    I live in sunny So Cal. What are "Snow" tires? :ROFLMAO:
  10. Air_Boss
    3,952
    1,083
    New Yawk
    They're like the Dick Cepeks you use on the sand dunes...
