Arggg Stupid auto default to EV
Discussion in 'Prime Main Forum (2017-2022)' started by SteveMucc, Jun 14, 2018.
  1. SteveMucc
    SteveMucc Active Member
    391
    268
    Kentucky
    Ok... so how many people carefully plan their EV/ICE mix in order to maximize their energy usage/MPG on a commute? And how many people have pulled into a coffee shop, turned the car off, gone inside (usually because the drive through line is a mile long), gotten back into your car and forgotten to switch it back to the desired mode only to realize that you've now shot your EV wad when you feel the tell-tale thunk of the ICE starting. Sigh...
  2. schja01
    schja01 Senior Member
    1,821
    1,208
    Chicagoland
    2024 Prius
    Limited AWD-e
    Absolutely never. But then again I won’t have my new car for another week. :)
    You’ve given me something to watch for.
    Thanks,
    J
    Dudley1030 likes this.
    51,154
    you'd be amazed how many clamored for ev only start up when toyota was designing the pip. customization of default would be nice though.
  4. Salamander_King
    Salamander_King Senior Member
    11,009
    8,935
    New England
    Not often. My daily drive is short enough and all on rural backroads, I don't worry about switching back and force between EV and HV. I just run EV until it runs out of juice, then ICE kicks in.
  5. breakfast
    breakfast Active Member
    266
    199
    Never forgot to set the right driving mode. But, then again, I make my own coffee before I leave :)
    Nic Steussy and benagi like this.
  6. CraigM
    CraigM Active Member
    208
    208
    Portland, Oregon
    Yep, has happened twice. On a road trip where I wanted to save the EV portion for city driving at the other end. Pulled into a rest area to take care of "personal business" and then got back on the freeway. Miles down the road I noticed the low EV range remaining. Happened twice, at the SAME rest area :)
    SteveMucc likes this.
  7. schja01
    1,821
    1,208
    Chicagoland
    2024 Prius
    Limited AWD-e
    Solution:
    Slap this on your NAV screen before you leave the car.
    I got this on eBay dirt cheap. :)
    J
  8. SteveMucc
    391
    268
    Kentucky
  9. Dudley1030
    Dudley1030 Active Member
    200
    139
    Lawrence, KS
    LOL
    Hmmm... might want to see your doctor about your urinary frequency. MIght have BPH, OAB or some other genitourinary disorder. :eek:)
    #9 Dudley1030, Jun 18, 2018
    benagi and CraigM like this.
  10. SteveMucc
    391
    268
    Kentucky
    back in NJ rest stops were used for other things... just ask our ex-Governor.
    markrivers and Dudley1030 like this.
  11. bisco
    51,154
    same here, hotel rooms must have been too expensive.:whistle:
  12. Ascegan
    Ascegan Junior Member
    edison, nj
    Frequently- I live in an apartment so I cannot charge at home, so I have to ration my EV use to last between weekends when I change at my in-laws. EV is great for quick errands. But one trip in the highway and all the EV is gone the rest of the week. —>Toyota should allow a customized default in their info-tainment center.
    That’s the best use of that quagmire of a NAV screen
    #12 Ascegan, Jul 4, 2018
  13. Lee Jay
    Lee Jay Senior Member
    5,850
    4,030
    Westminster, Colorado
    Simple - I drive all EV to work.
    Never - never had a cup of coffee, never stop on the way to work for anything anyway.
    If the car didn't default to EV, I would consider that a MAJOR defect because that would mean the engine would start and go through the warmup cycle before I had a chance to stop it. Since 99% of my in-city driving is all EV, that would be a major bummer.
    heiwa, bresna, Mark57 and 3 others like this.
  14. breakfast
    266
    199
    The #1 benefit to the Prime defaulting to EV mode is to reduce emissions for short trips.
    Since one of Toyota's main goals with the Prius (as stated by Toyota themselves over the years) is to reduce emissions, it makes total sense for Toyota to make EV mode the default now that it finally has a model (the Prime) with the ability to offer the full driving experience (flooring the accelerator, high speeds, etc.) in EV. After all, the warm-up cycle is the most-polluting, least-efficient part of any modern gas engine's operation.
  15. jerrymildred
    jerrymildred Senior Member
    11,517
    14,137
    Tampa, FL
    Ditto!
    Mark57 likes this.
  16. SteveMucc
    391
    268
    Kentucky
    Sure, that makes sense for some of the drives, but when you have multi-hour commutes (into NYC from... well, basically anywhere), that cup of coffee sometimes sounds really good.
    In any case, things like this should simply be a configuration option.
    If a tesla had an engine, I would expect that THEY would have made it into a configuration option.
    Which brings up another sore point.. (not to hijack my own thread, but...). Why don't they make all those damn ODB configuration entries simply configurable via the GUI? they made them configurable in the first place but there should be no reason you need to go to a dealer to have them changed (and potentially changed back should you decide you liked the default better).
    Many car manufacturers haven't realized quite yet that they have "power users" who are more than happy to use their cars as much as toys as cars, and will happily pay for that ability.
  17. bisco
    51,154
    prius especially, more than any other toyota hybrid.
  18. jerrymildred
    11,517
    14,137
    Tampa, FL
    That's a really good point. It's just a matter of programming, now that they have the touch screens. They could program all the user configuration options into the touch screen. But it might take the addition of a little more memory to the screen's hardware for those interfaces. A minor expense in the grand scheme of things.
  19. bisco
    51,154
    prius owners want ev default and prime owner(s) want hv default.:cool:
    SteveMucc, jerrymildred and schja01 like this.
