Arizona Prius owners and tire recommendations
Discussion in 'Gen 2 Prius Main Forum' started by recycleman, Aug 4, 2011.
  1. recycleman
    recycleman Junior Member
    43
    Chandler
    What tires are popular to the AZ crowd? I have an 05' with Integrity's and and it's time for new kicks.
    Thanks!:rockon:
  2. Patrick Wong
    18,200
    6,493
    I have this tire on both Prius. I recommend this model if you do not drive in snow.
    Ecopia EP100: Bridgestone Tires
    I bought one set at Costco and the other at Discount Tire.
  3. Scotty Danger
    Scotty Danger Junior Member
    86
    Scottsdale
    I couldn't agree more. I was in Scottsdale for 1.5 years and drove all over state (even off-roaded the Prius on the Navajo Reservation lol)
    I averaged 58.5 MPG. I even had a few 60+ tanks. These tires are great when those crazy monsoons hit (the Integrities had horrible wet breaking performance).
  4. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Patrick, what kind of wear are you observing on those tires? I've seen reports of low mileage (40k). I hope that is not the case otherwise a higher mileage tire with a tiny bit less fuel efficiency would be better economically.
  5. Patrick Wong
    18,200
    6,493
    There are 13K miles on the tires installed on the 2007 (which is now at 35K miles odometer reading.)
    The tire tread depth now: 8/32" on front, 9/32" on rear. Hence, 8.5/32" average
    Assuming a linear tread wear rate, a starting tread depth of 10/32" and end of life at 2/32": 1.5 / 8 = 0.188. 13K miles / 0.188 = 69K miles extrapolated life.
    I typically will replace tires at 4/32" tread depth remaining, so my realized tire life will be lower.
    To provide a comparison, I replaced the original equipment Goodyear Integrity tires at 22K miles.
