Armrest Replacement
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by jk823, Feb 16, 2019.
  1. jk823
    jk823 Junior Member
    98
    Los Angeles CA
    the plastic underneath the armrest on my 2009 Prius has cracked and now the leather sags. I'm afraid my elbow is going to poke through at some point. Is there an easy way to fix/replace this? Is it a particularly expensive part?
  2. Jmack111
    Jmack111 Member
    370
    78
    Tacoma wa
    Allied Express tan matches perfectly Screenshot_20190216-145354_AliExpress.jpeg
  3. audiodave
    audiodave Active Member
    787
    268
    US
    It's attached to the door panel with melted plastic. But you can knock the plastic off the tops and use quarter inch screws to hold it back on. Upholstery will need to be removed to cover something over the broken area then everything put back. My plastic wasn't broke but I wanted more padding and new material. Did myself since upholstery is my job.
  4. Jmack111
    Jmack111 Member
    370
    78
    Tacoma wa
  5. audiodave
    787
    268
    US
    SFO likes this.
  6. audiodave
    787
    268
    US
  7. bobodaclown
    bobodaclown Member
    214
    71
    Mine broke on the passenger side. I ended up fixing it by using hot glue and a supporting piece of plastic underneath. Took off the door panel it's easily acceptable.
    SM-T700 ?
  8. johnjohnchu
    johnjohnchu Active Member
    211
    104
    Added a piece of white Styrofoam inside door panel for support. Now it is rock solid.
  9. audiodave
    787
    268
    US
  10. johnjohnchu
    211
    104
    Yes, I think it was from a LCD TV shipping box.
