As GM (Volt) Goes... so goes the nation
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Octane, Mar 17, 2011.
  1. Octane
    Octane Proud Member of 100 MPG Club
    384
    56
    The Swamp, Southern FL
    Chevy Volt: The Car From Atlas Shrugged Motors
    Chevy Volt: The Car From Atlas Shrugged Motors - Forbes.com
    ...a GM engineer swore to me that the internal combustion engine in the machine only served as a generator, kicking in when the overnight-charged lithium-ion batteries began to run down. GM has continually revised downward its estimates of how far the machine would go before the gas engine fired, and now says 25 to 50 miles.
    It turns out that the premium-fuel fired engine does drive the wheels--when the battery is very low or when the vehicle is at most freeway speeds. So the Volt really isn't a pure electric car after all. I'm sure that the people who designed the car knew how it ran, and so did their managers.
    Why then the need to keep this so quiet? It's doubtful that GM would have gotten such a subsidy if it had been revealed that the car would do much of its freeway cruising with a gas engine powering the wheels. While the Volt is more complicated than the Prius, and has a longer battery-only range, a hybrid is a hybrid, and the Prius no longer qualifies for a tax credit.
    In other words, GM was desperate for customers for what they perceived would be an unpopular vehicle before one even hit the road. It had hoped to lure more if buyers subtracted the $7,500 from the $41,000 sticker price. Instead, as Consumer Reports found out, the car was very pricey. The version they tested cost $43,700 plus a $5,000 dealer markup ("Don't worry," I can hear the salesperson saying, "you'll get more than that back in your tax credit!"), or a whopping $48,700 minus the credit.
    And now we know why GM has continued their lying sacks of feces ways. They wanted to bilk the American people out of a tax subsidy they don't deserve. This company will never change.
  2. Rybold
    Rybold globally warmed member
    2,760
    322
    Southern California
    There will be no Volts for now. A GM representative was on the news earlier tonight, saying that the Volt's transmission is made in Japan, and production of that part is currently on hold.
    Other GM vehicles, assembled in the United States are on hold due to Japanese parts:
    http://www.nytimes.com/2011/03/18/business/global/18auto.html?src=twrhp
  3. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
  4. hampdenwireless
    hampdenwireless Active Member
    1,104
    86
    Baltimore MD
    Wow. One word can make a big difference. The OR should be an AND. The Volt does not use the gas engine during most highway driving under electric mode. Once the battery is low AND the car is at highway speeds the gas engine is used to drive the wheels.
  5. hampdenwireless
    1,104
    86
    Baltimore MD
    Wrong. There is no shortage of Volt trannies. The part is made in Japan but the volumes of the Volt are so low they have a supply. The article mentions a pickup that they are out of transmissions for.
    "In an e-mail response to a telephone query Thursday from Inside Line, General Motors spokesman Rob Peterson said, "Volt production is currently not impacted by the crisis in Japan. We continue to monitor the situation closely as we do for all GM products.""
  6. john1701a
    john1701a Prius Guru
    12,755
    5,245
    57
    Looks like the "Made in America" boasting was just hype. With the battery coming from Korea and the transmission from Japan, it's about as pure as the "no gas" claims.
    357 are listed as available for immediate purchase on AutoTrader right now. So, there's little concern about inventory at the moment anyway.
    3 people like this.
  7. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    357 of them?! That should last until next decade...
  8. hampdenwireless
    1,104
    86
    Baltimore MD
    The battery cells come from Korea but the battery unit is made here. That does keep a substantial amount of the labor here in the USA.
    The transmission is made by the same company in Japan that made the Prius Gen2 PSD.
  9. hampdenwireless
    1,104
    86
    Baltimore MD
    More like 1 to 1.5 months.
  10. Corwyn
    Corwyn Energy Curmudgeon
    2,171
    659
    23
    Maine
    "It turns out that the premium-fuel fired engine does drive the wheels" I am confused. Are they saying that there is a mechanical linkage between the ICE Engine and the drive train, and that GM has been lying about, and hoping no one would notice? That sounds crazy. Confirmation anyone?
  11. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Another possibility is that their battery pack cannot or isnt designed for the current pull required at higher highway speeds, so running the engine generates enough to overcome that? Just another guess. It would mean they werent lying, they just didn't design it well.
  12. Flaninacupboard
    Flaninacupboard Senior Member
    1,297
    213
    Midlands - UK
    It uses a power split device and three clutches, giving it a "series" mode (MG2 powers the wheels, MG1 is spun by the ICE, and MG1 is disconnected from the PSD) an EV-only mode (MG2 powers the wheels, and MG1 is used as an E-CVT to reduce MG2 speed, ICE is disconnected from PSD) and a parallel mode (MG2 powers the wheels, the ICE spins MG1, and MG1 is operating as both E-CVT and electrical generator, all are connected to PSD)
    So it functions the same way as the prius with one advantage, it can run in EV mode at any speed without overspeeding MG1 or spinning the ICE (even gen3 must spin the ICE with no fuel over 46mph) but the disadvantage is it requires 3 clutches, and presumably the mechanical switch between modes cannot be as fast as the prius switch which is software only.
  13. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,997
    Fort Lee, NJ
    The gas engine can drive the wheels as low as 30 MPH.
  14. usbseawolf2000
    14,487
    2,997
    Fort Lee, NJ
    GM Lied: Chevy Volt Is Not a True EV
    Inside Line article said the gas engine would turn the wheels near 70 mph. Since then GM engineer accurately stated that it really depends on the torque demand and it could be as low as 30 MPH.
    2 people like this.
  15. hill
    8,177
    The "same ol' - same ol' GM P.R. spin is just around the corner:
    "No one wants hybrids & EV's ... we just proved it, by trying to sell one ... both being wrapped in the one car ... the Volt"
    How much is Lutz getting for retirement?
  16. malorn
    malorn Senior Member
    4,281
    59
    "Somewhere in Flyover Country"
    They want hybrids and EV's, they just want them sized in an equinox(rav4), traverse(highlander), tahoe(sequoia) size. When that happens they will sell like crazy.
    Why the despise of Lutz? He is not pc, but he has a pretty sterling track record in the automotive world, startin gwith BMW in the 70's.
  17. hill
    8,177
    Malorn ! ! . . . you're back!
    Remember you said you'd sell me a Volt when they finally came out?
    Um . . . looks like you won't have to, with so many of them languishing on the market. What a shame ... GM gearing up to make 100,000 of 'em per year. Sheesh 100,000 Volts a year ... it's like GM building 100,000 Hummers a year ... never thinking that people don't want 'em. It's very sad the the higher ups at GM just won't listen.
    And by the way . . . this aint the 1970's any more ... only GM still hasn't realized that yet. And here we are with Gas going up to $4 / gallon. How's things at the dealership btw. It must be hard trying to sell escalades at a time like this ... or a 37mpg hybrid touted as "made in the USA" ... only not.
  18. Ryanpl
    Ryanpl Active Member
    780
    158
    Brooklyn, NY
    If we want answers to how and why the Volt works Hobbit needs to get his hands on one and take that puppy apart.
  19. malorn
    4,281
    59
    Right now they are only available in a handful of states(not including mine). Huge mistake. My stores have 8 sold orders sitting unfulfilled.
  20. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    I'm not going to bash the Volt until it's actually released here, I've driven one and made my mind up. All this assumes they will actually release one over here in 2012, which judging by the sales in the US might not happen.
    GM do seem to be giving it a half hearted marketing campaign. You'd expect to see Volts product placed everywhere.
