ASC/TRAC light after rotor/pad change
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Jim Perry, Jan 14, 2016.
  1. Jim Perry
    Jim Perry Junior Member
    Green Valley, AZ/Larsen, WI
    2020 Prius
    I just changed the rear rotors and pads on a 2010. Mileage is 145,000, owned since new. It seems the ASC/TRAC light now flashes when pedal is depressed (put car in drive in garage - depress pedal - one beep and light flashes). I had trouble with one of the the caliper pistions, and screwed it all the way out and lost 1/2 teaspoon of brake fluid, so I may have introduced air into the line. Would this cause this? Is there anything unusual about bleeding brakes (as compared to non-regenerative braking cars)?
  2. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    Did you unplug battery when doing brakes?how did it leak anyway?
