Asking for tips and ideas to check the car before buying
Discussion in 'Prius c Main Forum' started by Mohammed Rafidh, Jun 15, 2024.
  1. Mohammed Rafidh
    Mohammed Rafidh New Member
    Tbilisi, Georgia
    Is it a good idea to buy a Toyota prius c, which have done 165000 kms in 2024 ?
    The car looks fine both exteriorly and interiorly.
    I am worried and concerned about its battery health, so can anyone tell how can i check its battery health? Is there any tips ?
    My purpose is to drive it for two years as i am a foreign student who is planning to buy one in georgia tbilisi. Later i need to sell it. So will it be a good option for me ? Is it reliable?
    Is 1650000 km a problem?
  2. Mohammed Rafidh
    Tbilisi, Georgia
    Sorry, it is a 2012 model.
  3. Tideland Prius
    16,121
    Hello and welcome to PriusChat!
    Usually you would need a dealer to check out the battery health using diagnostic tools but there are a few things you could use as a proxy for a dying battery.
    1. When the car is running, check to see that the battery maintains a charge. Toyota hybrids like to keep it around 60% for maximum longevity. On the battery meter in the car, that also roughly translate to 60% of the icon (note that a full charge in the battery display in the car is actually only 80% and an empty battery is actually only 20%. Again, this to maximise longevity). See if the battery meter stays steady as you test drive the car and it doesn't constantly drain to low charge and then back up again. The engine will also run more frequently than normal and won't shut down as often when stopped at a traffic light
    2. Check the battery air filter. A well maintained car should have the filter cleaned or replaced. If it's dirty, then air hasn't been able to go into cool the battery and it could shorten the life
    It depends on how the previous owner(s) treated the car but typically, under normal operations, Toyota hybrids should be able to run over 200,000km. My 2005 Prius lasted 245,000km before needing a new battery for example. Prius taxis run to 400,000-500,000km before needing a new battery but you can see, it depends on the operations.
  4. Leadfoot J. McCoalroller
    7,130
    6,677
    Pennsylvania
    2018 Prius c
    Hard to say-
    You should be aware that the batteries in these cars were built to last "about ten years."
    ...so a 2012 battery would be pretty worn out by now, if it is still the original.
