at what percent of charge should the ICE turn on when parked?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Beachbummm, Sep 18, 2016.
Tags:
  1. Beachbummm
    Beachbummm Senior Member
    1,160
    392
    2008,156000 miles,original battery pack,new 12 volt
    I recently noticed the ICE only comes on when my battery is down to the last 2 bars (pink/purple/whatever color they are). I had the car on in park no ac or radio on for about 25 or 30 mins and ICE didn't turn on the entire time.
    It runs until I have one blue bar then turns off..
    is this normal? If not what does it indicate the problem could be?
    I never have that screen on the display, always the NAV. so I haven't noticed this before..
  2. Mendel Leisk
    38,893
    Seems normal. Why did you do this btw? Or just forgot to turn it off?
  3. Beachbummm
    1,160
    392
    moved it out of the driveway to cut and edge the lawn and forgot to turn it off...when it started I was like, oh $#!t and saw how low it was.
  4. drysider
    drysider Active Member
    823
    332
    Liberty Lake WA
    Mine (Gen 3) also comes on around 2 bars. It will also come on to keep the coolant warm.
  5. Beachbummm
    1,160
    392
    OK thanks..I always thought it came on at around 60% built up to 80% than shut off..first time I let it sit this long so I wasn't sure
