At what point should you service the battery?
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Matt98svt, Jun 3, 2023.
  1. Matt98svt
    Matt98svt Junior Member
    60
    South Carolina
    2015 Prius v wagon
    My Prius just turned 185k and is on the original traction battery with no issues so far. I have noticed my mpg has slipped a small amount but the car still averages 46 mpg. I have never used the Dr Prius app to actually test the battery but I see a lot of post in which people are balancing their cells and that seems to give the battery new life. As well as cleaning or replacing the copper terminals that corrode over time inside the traction battery. Is this maintenance that should be done preemptively or should I just wait until I get the red triangle? If I’m still getting pretty good gas mileage do I stand much to gain in mpg or longevity if I serviced the battery now? Thanks
    49,693
    yes, it needs to be done before there is a problem. it won't work after, so now would be a good time
    ukulelegeek likes this.
  3. Tim Jones
    Tim Jones Senior Member
    1,708
    553
    SE Texas
    2011 Nissan LEAF
    you are just at the year and miles for the battery and everything else to start going bad..... $$$$$$$$$$$$$$$$$$$$
  4. Leadfoot J. McCoalroller
    7,237
    6,784
    Pennsylvania
    2018 Prius c
    For my money, if you're going to do anything, do it between the 5 and 7 year mark.
