At Whit's End, Need Help With Suspension Noise!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by BigED, Oct 9, 2010.
  1. BigED
    BigED New Member
    23
    Atlanta
    You may have seen my posts a few months back regarding this knocking/clunking sound I've been experiencing.
    Well, even a supposed Toyota specialist shop couldn't figure it out.
    Replaced:
    Shocks
    Strut Mounts
    Inner Tie Rods
    Outer Tie Rods
    End Links
    Engine mount (yup, that Toyota specialist shop thought that would do the trick)
    The ball joints keep passing tests, two different shops swear they're ok.
    The road by my house is being repaved, as such, it's really chewed up, and when driving over it, it truly feels like the whole front end of the Prius is going to fall off. It's like the loud, dull, clanging of metal bars.
    Yet, nothing underneath shows any sign of wear or looseness whatsoever?
    I guess I'm going to have to go to the dealership, but I don't want to be in the situation where they do what they believe will solve the problem, and it doesn't.
    Help?
  2. Patrick Wong
    18,198
    6,464
    Re: At Wit's End, Need Help With Suspension Noise!
    Hmm, 120K miles. Have you found that the problem has diminished after replacing all of the parts in your list, or not? If it diminished, what produced the greatest improvement?
    How about the front anti-sway bar bushings?
    I assume that your shop replaced the engine mount cited in the TSB. There are other mounts that secure the transaxle and engine to the vehicle. Have they been looked at?
  3. BigED
    BigED New Member
    23
    Atlanta
    The problem has actually gotten progressively worse.
    The anti-sway bar bushings appear to be ok. There are two bushings, when the end links are removed I checked them out, there appears to be no play, nothing strange about them. Of course, under load that may be a different story.
    As for the shop, yup, they replaced mount cited in the TSB.
    Thing is, sometimes I swear it's my steering column, the feedback it provides seems to go right up through. Literally, the column/front end feels like loose metal that's coming apart, and it's LOUD.
    I removed the rubber "boot" and fished around the steering linkage, all appears well there too. It is the most bizarre problem I've ever encountered.
    I seriously wish the damn thing would just break somewhere!
    The only thing I can say for certain, is it happens when I hit relatively small bumps in the road, or continuous road imperfections which really, REALLY, express the issue. It also seems to be more pronounced on the driver's side.
    It's funny, as I'll try and trigger the problem by using a long metal bar under the tire (when the vehicle is lifted and the front wheels are approximately six inches off the ground) and moving it up and down to varying degrees, not a thing.
  4. jdenenberg
    jdenenberg EE Professor
    3,837
    1,827
    Trumbull, CT
    2020 Prius
    LE AWD-e
    My dealer just replaced the upper steering column assembly in my 2004 Prius (at 180,000 miles). This fixed a periodic "Clunk" felt mainly in my hands when going over a bump. The repair cost $90 to diagnose and $800 to do the job. They told me that the mechanism that allows the steering column to collapse in an accident was loose. Since the "Clunk" is now gone, I have to believe that they knew what they were doing.
    JeffD
