Atkinson engine without the motor assist?
Discussion in 'Gen 3 Prius Main Forum' started by Troy Heagy, Apr 25, 2013.
  1. Troy Heagy
    Troy Heagy Member
    1,218
    I've always wondered how the Prius would "feel" if there was no electric assist. Has Toyota or anybody else used the Atkinson engine inside a standard car? How did it drive?
  2. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    Try driving ur Prii with 2 HV bars left.......this will give u an idea how it would feel.......it's pretty gutless. :D
    Not sure if its been used without the electric motors.
  3. Troy Heagy
    Troy Heagy Member
    1,218
    So in theory it could be done. I wonder why Toyota never made a high MPG car with just the Atkinson engine..... like in an Echo or Yaris or something.
  4. css28
    css28 Senior Member
    1,566
    442
    Suburban Detroit
    ...cause there's not a big market for a car that feels more gutless than a Mercedes 240d?
    sdtundra likes this.
  5. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    My rudimentary understanding of the Atkinson cycle engine is that it produces more efficient fuel economy at the cost of a loss of power density.
    So it's great in a Hybrid that is being augmented by an electric motor.
    But there is reason you don't see pure ICE vehicles with the Atkinson Cycle. To really be viable it needs augmentation for automotive use.
    I mean in "Theory" you could tie horses to the front of the vehicle and turn it into a buggy. Doesn't mean anyone would want to do it.
    If it was as simple as simply doing it? Yeah you'd see a lot of ICE Atkinson Cycle engines. The absence of this reality tells me it simply is not very viable.
    mad-dog-one likes this.
  6. JimboPalmer
    12,470
    6,863
    Greenwood MS USA
  7. Troy Heagy
    Troy Heagy Member
    1,218
    They make 3 cylinder cars that are gutless. (Not sure about Toyota specifically, but other companies do.) Those seem to sell well in high-cost areas like Europe. So why not use the Atkinson engine if it truly is an efficient cycle?
    [edit] Well there you go. Mazda did it. Mazda seems to like experimenting with small engines and different engines (like the rotary)
  8. The Electric Me
    9,083
    5,798
    Yeah, but a supercharger is augmentation.
    Has anyone ever "just used" an Atkinson Cycle engine without augmentation? Everything I read is that it simply does not create enough power density to be used as a stand alone power option in an automobile.
  9. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    You don't understand fully. At 1200 RPM idle you -could- drive an Atkinson engine only car. But what would be the point? With a 1200 RPM idle it would get mediocre mileage. Oh, and make no mistake, it would be VERY gutless. With the Prius battery at min. you still get no idea how gutless, as you -still- get lots of assist.
    Do you really want to have to get out and push to get it going? ;)
    People seem to think you can change the Prius system to "try out" various different things.
    WRONG!
    The Prius is designed as a system, and all parts have to work for the Prius to work.
    Les_PL likes this.
  10. JimboPalmer
    12,470
    6,863
    Greenwood MS USA
    I have driven cars with as little as 52 HP, they simply would not be marketable in today's car market.
    0 to 60 in 17 seconds. Radio optional.
    Popular Science - Google Books
  11. s3nfo
    s3nfo Member
    164
    24
    San Diego, Ca
    It's all about the torque, that's why electric assist works so well with the Atkinson cycle engine, instant torque from the motor(s). Even "gutless" 3 cylinder engines have gobs of torque at low RPM when compared to an Atkinson cycle engine, so starting from a standing stop is still fairly acceptable with a "gutless" 3 cylinder Otto cycle engine, whereas an Atkinson cycle engine would take hours ( yes, I'm exaggerating) to get up to usable speeds from a standstill.
  12. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    A Prius 1.8l Atkinson cycle has about the same torque as a 1.4-1.5L Otto cycle. The difference is greatly exaggerated in folklore.
  13. kithmo
    kithmo Couch Potato
    2,404
    2,773
    47
    South Yorkshire, UK
    Is the 1.5L in the Gen2 Prius an Atkinson ?
  14. css28
    css28 Senior Member
    1,566
    442
    Suburban Detroit
    Yes.
  15. Troy Heagy
    Troy Heagy Member
    1,218
    Excellent answer. So basically the 1.8L Atkinson engine is still more-powerful than the 1.3L in the original Civic Hybrid or the Insight G2.
    The 1.5L atkinson would be weaker
