Atlantic Hurricane season 2019
Discussion in 'Environmental Discussion' started by tochatihu, Apr 23, 2019.
  1. tochatihu
    tochatihu Senior Member
    9,548
    3,683
    Kunming Yunnan China
    2001 Prius
    51,148
    oy, spring hasn't even arrived yet
  3. tochatihu
    9,548
    3,683
    2001 Prius
    There is a nothingburger off east FL coast that probably won't get named Andrea.
    Elsewhere in world of Coriolis gone sadly wrong, Indian Ocean is hard at work. Mozambique and Madagascar took a couple of hits. India does large evacuations before Fani arrives. In terms of satellite imagery of such events, Fani is about as good as it gets. Vast, symmetrical, and with a very tight eye.
    51,148
    feels like we're in the middle of a 5 week nor'easter here
  5. tochatihu
    9,548
    3,683
    2001 Prius
  6. tochatihu
    9,548
    3,683
    2001 Prius
    Federal Emergency declaration has already been made and recovery materials and peeps pre positioned. Acting FEMA Director is a 'career guy' who managed deepwater blowout, so not much better could be hoped for there.
    Mississippi River (down yonder) generally crests in springtime at about 14 feet. Rains have been more and later this year, so it was at 16 feet. Recent local rains bumped it up to 17. Levees are improved since 2005 and not anywhere below 20 feet (I think).
    New local rain is expected to be a lot. This storm Barry is is unimpressive among hurricanes but there will be several feet of storm surge. I doubt that large-scale flooding can be avoided (or quickly pumped out) even though local news sources are not panicking on that.
    Storm may not become hurricane, but it comes to a particularly bad example of coastal engineering at a particularly bad time. Best wishes for all nearby.
  7. tochatihu
    9,548
    3,683
    2001 Prius
  8. bwilson4web
    16,012
    I was impressed that it did not spawn from a tropical depression between Africa and the Caribbean. It came from an ordinary low pressure system that wandered over the Gulf of Mexico and then turned on. This may be more common than I'm aware of but I found the origin interesting.
  9. tochatihu
    9,548
    3,683
    2001 Prius
    TS Barry center of circulation has already come ashore but because of shear, most water-to-fall is still in Gulf of Mexico.
    Predicted rainfall has been halved, and predicted storm surge cut to one third. This is obviously all very good news and New Orleans area flooding will not be a lot.
  10. bisco
    51,148
    still time to move out!(y)
  11. tochatihu
    9,548
    3,683
    2001 Prius
  12. bisco
    51,148
    perfect. we had some pretty good rain today, and more to come, unless they're wrong
  13. Leadfoot J. McCoalroller
    7,859
    7,326
    Pennsylvania
    2018 Prius c
    We just took an incredible thunderstorm here in PA. My house has a moat now. Water in the basement. Neighbors going door to door checking on each other. Highway flooded over, traffic backed up, emergency vehicles seen swimming.
    It’s draining now but wow that was really something else. Neighbor tells me it’s the worst he’s seen in 30+ years.
  14. tochatihu
    9,548
    3,683
    2001 Prius
    Saw some of that action on lightningmaps.org :)
    Guadalajara MX had a hail event with ~1 meter accumulations. A fella would notice that...
    fuzzy1 likes this.
  15. ice9
    ice9 Active Member
    581
    344
    norfolk va
    2018 Prius
    It is not that unusual for this time of year. The first tropical cyclones in the Atlantic season often form either in the gulf or off the US east coast, and are often triggered by spurious weather conditions. Later in the season, tropical cyclones typically form in the Caribbean - and even later than that; off the African coast. What was unusual about Barry, was the bizarre track of the spurious low pressure system over land before it went out over the gulf to become a tropical cyclone. However, I do recall early predictions, when the low pressure system was over Georgia, that it might happen.
    #15 ice9, Jul 17, 2019
  16. bwilson4web
    16,012
    One prediction from the Climate models are abnormally high rainfall events in some areas because of the increased water evaporation. Counter intuitive, there will also be droughts in other areas.
  17. tochatihu
    9,548
    3,683
    2001 Prius
  18. ice9
    ice9 Active Member
    581
    344
    norfolk va
    2018 Prius
    I would tend to agree. Both higher rainfall and droughts will occur. Individually, both are short term events. The droughts, however, are difficult to document as causally related to climate change over the long term (30 years). The increased rainfall, on the other hand, should be easy to document as such. Not that I think they will necessarily continue to increase. I believe that the rainfall we are experiencing now is the "new normal".
  19. bwilson4web
    16,012
    Climate change?
  20. fuzzy1
    10,335
    Our hay crop took a very serious hit last week with just 2 inches of hail accumulation (at least -- the tub used as ad hoc gauge was tilted and overflowing), knocking our best fields nearly flat. Largest stones in the 1" to 1.25" range, though the bulk in the 0.5-0.75" range. We heard that a section of nearby highway, on the other side of a ridge, had 6", so the road dept pulled out a snowplow.
    But apparently the core path was under a mile wide. Neighbor fields just a mile north had far less, places three miles north had only light rain, while others east and west were hit similarly hard as us, one home suffering lots of broken windows and siding. (We lost a single barn pane, but those are cheap and weak compared to house windows.) There are no homes or fields to the south, but an acquaintance using a horse trail the next day found the edges of the main destruction path to be under a mile apart. Tree and brush leaves half stripped, lots of fruit knocked down, ditches still full of hail a day later.
    The crop destruction was worse than dad (80+) could remember, but matches a 1920s event that his dad described.
    If 2 inches can do this, I can't image what 1 meter of hail can do.
    #20 fuzzy1, Jul 18, 2019
