ATTN Prius owners!
Discussion in 'Gen 3 Prius Main Forum' started by dryrider, Apr 19, 2011.
  1. dryrider
    dryrider New Member
    28
    I have a 2010 Prius and the spaire tire under the rear floor with the jack bolted on top of it and the valve stem pointed down so you would need to remove everything to Ck the air had less than 40 psi in it! It needs 60psi....have it checked!:mad:
  2. joecwilson
    joecwilson 2014 Prius II
    17
    Chicago
    Did you find this out the hard way?
  3. dryrider
    dryrider New Member
    28
    No...Just Got lucky and checked.
    49,474
    yeah, i hate that design. although mine never loses air, i still feel the need to check it. if i'm lazy, i reach in and give it the squeeze test.
  5. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    Do u squeeze the Charmin in the grocery store too:D
  6. joecwilson
    17
    Chicago
    lmao, I was going to insert a smart a$$ comment too!
  7. bisco
    49,474
    yes, and that's not the only place.:rockon:
  8. walterm
    walterm Active Member
    466
    202
    34
    2022 Prius Prime
    The perfect accessory for this is an air hose extender - I got one from Amazon but those seem to be out of stock now. It was an "Accu-gage - Chek A Spare, Valve Extender". Perhaps Pep Boys/Napa auto stores have something similar.
    I ran the hose up into the small well on the driver's side of the cargo area where it's quite easy to get to to check pressure/fill if needed.
  9. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    You gotta be fast around these parts pardner. ;)
  10. sipnfuel
    sipnfuel New Member
    1,080
    174
    So. Cal.
    This reminds me that I need to pick up a 12V compressor next time I see one on sale.
