Atypical P0304 misfire
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by voltech444, May 20, 2025.
  1. voltech444
    voltech444 Junior Member
    28
    37
    Pontiac, MI
    Yes, I know misfires on third gen Prius have been covered here many times, but this one is a real head scratcher. I bought this 2010 Prius from a customer because the engine coolant pump failed, overheated the engine and blew the head gasket. A couple months before that it was having a misfire and we did the complete EGR cooler and EGR system cleaning, intake manifold, throttle body, fuel injectors, MAF sensor, new spark plugs, new air filter, PCV valve. It was running great until the water pump failed. I used a combustion leak detector fluid test to diagnose the head gasket which has worked on many other Prius.
    I had another 2013 Prius that had a good engine in it was running fine until it had some electrical issue I just didn't have enough time to troubleshoot. All the fuses and everything checked out good but when you would push the power button nothing would happen. Of course I tried a different power button as I have many extra parts around. Tried many things but had to move on to other jobs so I planned on using the engine from that one to fix the 2010.
    I did the engine and transaxle swap, I switched over the intake manifold, EGR cooler, all of those parts I had just cleaned out on the 2010 on to the 2013 engine. Also did an oil change, changed the transmission fluid. On its first startup it was running fine so I drove it home that night and on my drive back to the shop the next day I got to check engine light with a code P0304 misfire on cylinder 4. I thought maybe there was something loose maybe a hose had a leak something got damaged during the swap but I was unable to find anything. All the bolts were tight. I had a brand new set of ignition coils so I put those on. It seemed better but after driving it more had the code come back and then it gradually got worse. I used the leak detector fluid and wasn't getting any color change so there were no exhaust gases in the cooling system.
    I had another intake manifold and throttle body that I had already cleaned out in the ultrasonic Parts cleaner so I swap those in I also put in a different throttle body. That didn't fix anything so I tried swapping in some different fuel injectors, still got the misfire on cylinder 4. I did a compression test and all four cylinders are looking good between 150 and 180 PSI, all of them identical. I thought maybe something fell inside the engine or something got into there that was blocking the valve or something like that, so I looked inside all of the cylinders with the borescope and there was nothing in there, nothing unusual looking, cylinder four look the same as all the others.
    Keep in mind, this engine was running fine in the other car before I had that electrical problem. I inspected the wire harness on the coils, trying to see if one of the pins was backing out or not making a good connection, tried wiggling it while the engine is running but didn't make any difference. Check the fuel pressure, it was good. Of course, if it was something like the fuel pressure it should be affecting all of the cylinders and be giving a random misfire but it's always just cylinder number four. I thought why don't I try the ECM from the 2013 engine, so I swapped that in, no change, if anything it ran worse. I had another ECM from a 2012 I tried that, no change still misfire on cylinder 4. At this point I want to light the car on fire and be done with it LOL but I refuse to give up. I've tried spraying brake clean all around different parts of the intake manifold while looking at engine data from the scan tool, no difference. I replaced the intake manifold gasket, still nothing. I had a customer that needed some new ignition coils on their Prius so I took the new ones off of this 2010 because I figured it doesn't need new ones it doesn't care what it has it's just going to run like crap. I put some coils on it from the junkyard and all the sudden it's running better, not misfiring super bad but when you go and drive it and put the pedal to the floor, at a high load it's still misfiring on cylinder number four.
    The only other things I could try at this point is the leak down test but I don't see how it could be a head gasket failure when it has good compression and no exhaust gases in the cooling system. I was wondering if there is something with the variable valve timing or a lifter, maybe something with an exhaust valve. I have another set of fuel injectors that I cleaned out that I know we're working good so I'm going to try changing the fuel injectors one more time. Also worth mentioning I put some good premium gas in with some seafoam fuel cleaner but of course nothing worked.
    I've worked on so many of these 3rd gen Prius with misfires and I've always been able to figure it out. Usually it's a ignition coil or EGR system problem. I'm running out of ideas and patience with this one. What else could it be that would only be affecting cylinder 4?
    Mahalo for your help!
  2. PriusCamper
    PriusCamper Senior Member
    11,976
    4,867
    Pacific Northwest, USA
    So you're saying you swapped out the engine and transmission and replaced all the basic stuff with new stuff and you still have the same misfire? Did I read that correctly?
  3. rjparker
    rjparker Tu Humilde Sirviente
    9,477
    5,797
    Texas Hill Country
    An overheated engine causing a hg fail can be traditionally diagnosed with leakdown or combustion gas in coolant. A bent rod can result which can then be detected by compression.
    Most gen3s get hg leaks WITHOUT ever overheating. They show good compression and are negative on leakdown tests and combustion gasses in the coolant. Primarily because the amount of coolant fouling the plug is a few drops which often seals itself as the engine warms up. If run this way for weeks or months the coolant will start to drop, overheating alerts the driver and traditional methods then work.
    Have you tried pressurized coolant when cold and a dual view borescope?
    If that fails to how a leak then you may need to use scope based diagnostics. The learning curve may be worth it considering the alternative parts cannon costs.
    This video shows how concise that kind of diagnostics can be. This particular engine was a no start because of a vacuum line.
  4. Tombukt2
    Tombukt2 Senior Member
    11,971
    2,115
    Durham NC
    So you're using a borescope that can look back up like 90° almost up at the head gasket mating surface while it's in the spark plug hole just to be clear that's what you have to look for of course you know this already so I'm hoping that you know you're boroscope does this function or Trump what have you because I mean it sounds like you have seepage in number four just enough to give you fits but I guess you verified that's not the case and on to The next episode yeah I feel you buddy it really sucks
  5. voltech444
    28
    37
    Pontiac, MI
    Yes that's correct. Some of the parts like coils and plugs are new; the others are used but have been cleaned (like the intake manifold and throttle body) i cleaned the EGR passages in the intake manifold too
    I haven't noticed any coolant loss yet but maybe now that the misfire is more mild, I'll drive it more and see if the coolant starts dropping.
    I do not have a dual view borescope, probably time to upgrade to something better.
    I do have a 4 channel Picoscope and I also have a pulse detector attachment for it that I might busy out. I've only used the engine pulse detector a few times so I'll need to compare this Prius with another good one and study the waveforms; its might be able to tell me something. I was also thinking to back probe the fuel injector and coil to see the waveform while it's running. It's usually not necessary to do all of this but in this case, it's probably time for the big guns lol.
    No my borescope is pretty basic and can't bend that much. I've been meaning to order a better one anyways so I guess I'll do that soon. It doesn't have a real rough cold start like they do when the HG is leaking. It only misfires under load at low RPM. When I do a WOT test, it misfires initially but ince the RPM gets high, the misfire count drops low, but still registering some.
    #5 voltech444, May 20, 2025
  6. Mendel Leisk
    40,443
    What was the miles then? It likely had head gasket failure from the outset: EGR cleaning is always good, it’s the likely culprit in head gasket failures, but belated cleaning is not going to “undo” an already leaking head gasket.
    The detector you describe is likely the kind that checks for exhaust gas in coolant, which is not typically the head gasket failure mode.
    seems like you’ve run out of parts-cannon fodder, and inherited this head-scratcher: try a borescope inspection of combustion chambers, looking for presence of coolant.
    #6 Mendel Leisk, May 21, 2025
  7. PriusCamper
    11,976
    4,867
    Probably at this point, I'd reach out to: https://www.instagram.com/skimmilkhybrid/ and see what he thinks it most likely is... That dude has more hours of experience with Prius engines than anyone I know.
  8. voltech444
    28
    37
    Pontiac, MI
    UPDATE!!!
    Ok I finally had some time to take another stab at it and I finally got it fixed. Even though I had already changed the fuel injector on cylinder #4 I figured what the heck it's worth a shot. I cleaned and tested an injector and swapped it in, and the misfire finally went away! It's just crazy because I changed it once already. I tested the bad injector, it was firing on the tester but I'm thinking maybe I didn't clean it very well and it was partially blocked. That could be why the engine could idle fine but under WOT conditions it would misfire because it was out of balance with the 3 other injectors. Kind of similar to the hybrid battery modules have to all be very close in performance and play ball well with each other. I have seen on my scantool a feature for fuel injector balancing but I've never used it, but after this experience I should try!
    Thank you to everybody for their input and help on this!
    Brian1954 likes this.
  9. rjparker
    9,477
    5,797
    Texas Hill Country
