Audi A2 goes over 370 miles on one battery charge.
Discussion in 'EV (Electric Vehicle) Discussion' started by Scummer, Oct 26, 2010.
  1. Scummer
    Scummer Eh?
    174
    29
    Munster, IN
    3 people like this.
  2. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
  3. Rybold
    Rybold globally warmed member
    2,760
    320
    Southern California
    Sweet Electrons !!!
  4. bagwell
    bagwell Active Member
    592
    49
    the woodlands, tx
    nice!!!
    build it now!!!!!
  5. clett
    clett New Member
    537
    Scotland
    There is also an electric version of the A1, with rotary engine range extender.
    Review article here.
    Basics are:
    12 kWh battery
    31 miles EV range
    65 kg genset
    39 mpg (US) in range extended mode
  6. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,994
    Fort Lee, NJ
    I did some research on the battery technology they used. It doesn't last long. You'll get 500 cycles out of it. If it gets 370 miles per change, 500 cycles would come out 185k miles. That's pretty damn good!
    The real question is the cost.
  7. SageBrush
    SageBrush Senior Member
    11,627
    2,530
    Southwest Colorado
    Dennis, where did you find technical information ?
  8. usbseawolf2000
    14,487
    2,994
    Fort Lee, NJ
    It uses Lithium Metal Polymer. This one dated 2005 said 300 cycles. This one said over 500 cycles after improvements but it is dated 2001.
  9. usbseawolf2000
    14,487
    2,994
    Fort Lee, NJ
    Well, they claim 2,500 cycles without loss of capacity and 99.7% efficiency. It is hard to believe when others are struggling to get 500 cycles.
  10. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    i also saw the news report and also having difficulty finding any specifics about the battery pack. but still it shows that progress can be made. now if we can just get the EVs on the road. the more on the road, the more money will invest in promoting and marketing extended range options.
  11. Rybold
    2,760
    320
    Southern California
    Hmmmm. If the Audi gets 370 miles to the charge and the Nissan Leaf gets 100 miles to the charge, then I think Toyota needs to boost the plug-in Prius up a little from only 13 miles on battery only. It would be nice if it got at least 20 miles. 13 just seems waaaaaay low compared to other battery cars out there. I sure hope Toyota increases the EV range on the plug-in Prius before they release it to market.
  12. hill
    8,036
    Wow ... what a gas!
    Oh, wait . . . . . now I'll need new terminology.
    :p
    Anyway ... the A2 event actually happened last month.
    [ame="http://www.youtube.com/watch?v=9hrnrEiCJ-A"]YouTube - Audi A2 Sets Record For Longest Distance Driven By An Electr[/ame]
  13. Trollbait
    11,224
    Sweet, arguments over plug in hybrids might just become moot.
    That A1 plug-in serial hybrid is also impressive. It's what GM could have done with the Volt. Use a small ICE with a high power output to save space and weight, but still efficiently produce electricity. It even uses a tiny gas tank, 3 gallons. While most Americans won't think so, a daily 30 mile EV range with a conservative 100 mile CS mode is plenty.
  14. Rybold
    2,760
    320
    Southern California
    Hill, nice video and website. Thanks for posting! :)
  15. Duffer
    Duffer Member
    271
    Wow! It sure is great to see the Germans stepping up in the fight for electric vehicles. Up until this point the move to electric has been meandering at best with no one vehicle going over the 100mi mark. A range of 370 miles would be great for the majority of daily and weekly commuters.
  16. bedrock8x
    bedrock8x Senior Member
    1,483
    137
    I doubt it is running in EV mode for the whole 370 miles.
    Consider 4miles per kWh, 370/4 = 92.5 kWh, unless it has 100 kwh battery in the car, does not compute. The battery will wight >1000 lbs.
    It must be an extended range EV just like the Volt, so nothing to excite about.
  17. Duffer
    Duffer Member
    271
    I went through the article again and the A2 is an electric vehicle. No ICE was made reference to.
  18. andyprius
    2,212
    188
    I also thought the same, pure electric.
  19. daniel
    14,487
    1,518
    Spokane, WA
    Cool! -- And yes, according to the article it's electric. It would not be a world record if it had a range extender. Recommended speed is 80 mph, but I could live with that. The freeway speed limit here is 70.
  20. darelldd
    6,057
    388
    Northern CA
    If any of what the article says is true, then there is plenty to be excited about. We assume that the pack capacity is between 80 and 100 Kwh. The whole point here is that we need a high capapcity battery that is not too big and not too heavy. So I'm not sure what doesn't compute. There's no mystery as to how much energy we need to push a car this far. The only mystery is how to store it. We don't know how much the battery weighs until somebody tells us. Those who used to use lead acid wouldn't believe how much capacity they could have today with Li and for much less weight. Even if the battery does weigh 1000 pounds... so what? We have SUVs on the road today that weight 6,000 pounds with no battery pack!
    In the end, we simply don't have enough information and this couuld all be bogus. Anybody can make a car that'll go this far if you throw enough money at it, consume all the interior space and have no need to recharge it thousands of times. My hope is that something great has happened here. My educated guess is that the reality of the situation will fall somewhere between "ho-hum" and "gosh that's neat but not marketable."
