Audio display won’t show satellite radio
Discussion in 'Gen 2 Prius Audio and Electronics' started by Yogi Beer, Feb 8, 2021.
  1. Yogi Beer
    Yogi Beer Junior Member
    Mechanic had to remove dash to fix AC and now my radio won’t display Satellite screen, only am and fm. It has a SoundLinq3 box and Sirius XM Audio Interface Controller all hooked up behind the radio head unit, mag mount antenna too. Mechanic has no idea and I have troubleshot everything I can with checking connections and having Sirius try to send refresh signal. The audio display screen above the radio head unit won’t even go to the satellite section anymore, only AM and FM. Anybody have an idea?
  2. Yogi Beer
    Used to be able to tap AM button on radio to see satellite radio page on audio screen but now all I can pull up is AM or FM screens. Mechanic had to remove dash to fix AC and now this. He has no idea. Anybody have this problem before?
  3. davecook89t
    davecook89t Senior Member
    1,057
    789
    Washington State, Florida
    Four Touring
    From your description, I'm guessing the factory head unit in your car does not have the satellite radio option. Since the functionality of the factory head unit will be different than what you have, I believe you would only be able to get help from someone with the same unit as you have. When I search the forum, I see one other reference to a SoundLinq3 box in this thread. Possibly @Mgrad92 will be able to help you, since he/she has the same unit.
