audio loss on jbl sound system
Discussion in 'Gen 2 Prius Audio and Electronics' started by Gilbert, Oct 20, 2008.
  1. Gilbert
    Gilbert Member
    255
    this morning on my way to work i was listening to the radio, then suddently i notice that the sound in drivers side starts fading away, like if the gps was talking (reduces sound on your side to hear gps) but the gps was off and eventually i lost complete sound on that side then after a few secs it went back up. after about 10 mins i get to work and before i get out of the car it happens again, but this time it did not fade, just went out and came back after a few secs. anyone know what could be causing this? i have a 2008 with jbl sound system.
  2. rigormortis
    rigormortis Active Member
    1,340
    26
    san jose, ca
    if its not navigation, maybe the hands free ? search the forums for the lan monitor easter egg, download my knowledge base post, and you can read the codes to see if there is an actual problem.
    the prius mfd screen logs everything av-lan. even a shorted speaker wire
  3. Gilbert
    Gilbert Member
    255
    sweet, tried that and it sent me to the diagnostics thing. the screen shows the following
    EM's=ok
    navi=ok
    audio=ok
    g/w=ok
    dsp-amp=ok
    then i press the LAN MON button an shows me another screen with
    all of the above saying CHEK exept audio.
  4. Gilbert
    Gilbert Member
    255
  5. zenMachine
    zenMachine Just another Onionhead
    3,355
    300
    Does the sound fade out on both the lower woofer and the upper tweeter, or just the woofer?
  6. Gilbert
    Gilbert Member
    255
    the entire side of driver
  7. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    944
    118
    Los Angeles Foothills
    If you have a 2008, why worry about it! Thats whats the warranty is for. Sounds like a trip to the dealer is in order.
    Of course Murpheys Law will come into play here, and 1 block away from the dealer the audio will pop on full volume and be working perfectly, until you drive off the lot, and a block later, you loose your sound!!!
    Still, a trip to the dealer is in order on this one!!!
    Good Luck and let us know what they find!!
    73 de Pat KK6PD
  8. Gilbert
    Gilbert Member
    255
    haha now thats funny stuff. its actually like that. for every issue i take the car in for service, they can never replicate the issue. i drive away and there it is. sigh.
  9. rigormortis
    1,340
    26
    san jose, ca
    (keep in mind that chek might not actually mean anything, sometimes it logs too much)
    if it says chek then you should be able to read the codes under chek
    chek is a button, touch it
  10. Gilbert
    Gilbert Member
    255
    i did click it, it shows a bunch of codes
  11. drlehnherr
    drlehnherr New Member
    A somewhat related issue. I've got a 2007 Prius with factory XM and a jbl system, and the XM audio has started to spontaneously shut off. I'm still receiving a signal -- my display tells me what programs are currently on -- and I can still hear the audio from the FM and AM radio. I've also found that the XM audio comes back on if I shut off the car, and restart it. Anyone having similar problems?
  12. rigormortis
    1,340
    26
    san jose, ca
    write the codes down, download my pdf in the knowledge base, and you will know what
    the codes mean!!! a lot of people on here come up with some really sad replies saying these codes aren't important, but i copied them from a repair manual, and i was shocked to see how much info the prius logs.. like shortened speaker wires, rom and ram errors, blue tooth board failures, a lot of stuff. even upside down cds being played!
    anyway if there is an actual physical problem with the radio or anything av-lan related, the codes are stored in the mfd...
