Audio Memos?
Discussion in 'Gen 2 Prius Main Forum' started by clex, Jan 5, 2008.
  1. clex
    clex me
    Tacoma, WA. USA
    I see on the Mic & Voice recognition check screen that you're able to record and play your voice taken from the voice mic. Does anyone know if there's a function to record, save and play audio memos like that? I could have missed it in the manual but all I seen was text memos. I've only had it a week but am VERY impressed with the car despite less than expected MPG. This site is info full too.
    Thanks
  2. auricchio
    auricchio Member
    921
    Cambria, CA, USA
    No, you can't. That is simply a test facility.
    It's also prudent to steer clear of the setup screens!
  3. Doc Willie
    1,717
    142
    Out there, somewhere
    Wait a minute. Doesn't the telephone function allow you to record the names for phone numbers so you can voice dial them?
    You could set up a phone number, and record your voice memo as its name.
    Now how do you play it back?
  4. auricchio
    auricchio Member
    921
    Cambria, CA, USA
    Ah, that may be a workaround.
    I doubt you get much recording time for phone-names, however.
  5. clex
    clex me
    Tacoma, WA. USA
    Thanks for the replies anyways. I just thought it would be handy since driving time is when I think of all the things I should have done before driving to work. As far as the screens, I had to see them after reading about them here. No reason to return though. Thanks again
  6. Tideland Prius
    16,195
    If you have a navigation system, you can record a memo into the calendar
