Audio Trivia: Check Hybrid System P3190, P0A0F, P3000 - 8 second ride
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by STL314, Dec 18, 2024.
  1. STL314
    STL314 Junior Member
    22
    St. Louis
    Hi all,
    Starting my journey with a new problem. After some research I noticed there weren't many actual audio references to issues people experience - so sharing in case my scenario is common - or possibly not so common
    Issue occured after the car sat for a week and cold start with temperatures in the low to mid 30's F. Drove for 7 miles or so then at a stop the Check Hybrid System display came up, my heart sunk, towed home shortly thereafter.
    SOC is less than 20% so not going to try again until the battery is reconditioned or a confident fix is applied.
    Appreciate any thoughts on cause and possible fixes - but just hope the audio helps someone ou.as a reference point.
    An overview description:
    2011 Prius @ 193000 miles
    12v battery charged - 12.5 V
    EV original battery at 21% SOC (Dr Prius app)
    Engine Code: P3190
    Battery Code: P0A0F, P3000
    Maintenance performed at around 184000 miles:
    EGR System cleaned
    Air filter changed
    Spark plugs changed
    PCV replaced
    Throttle body cleaned
    MAF sensor cleaned (with MAF cleaner)
    Oil changed every 4000 miles
    Coolant: at Full line - no leaks
    Motor oil: Not chocolate milk - looks and smells like oil
    Cold engine start: sometimes grumbly after sitting for a few days - shakes/clatters but no coolant leak/loss after 9000 miles
    51,011
  3. STL314
    22
    St. Louis
    Hi Bisco, thanks for the links and I agree. I’ve only got Bluetooth scan tools and need to look into Techstream.
    Checked PCV hoses but it’s connected fine it seems.
    Performing maintenance on other family cars this week but hope to do more with the Prius this weekend.
    Will do the easiest stuff first like check/clean throttle body - look closer at pcv - clean MAF again. Likely will pull the ICE water pump just to see if it’s in good shape since it’ll be right there.
    I suspect fuel pump or delivery is keeping the engine from running - so will test that asap but need to create the pressure tester and do the plumbing, etc.
    I’ve never heard such a jarring clunk at the end of the start cycle like observed in the video - was/am concerned there’s something “bigger” and more catastrophic happening in the way all the things work. Would appreciate a comment on whether the noise and behavior there is expected - given the engine I think is not starting at all, just spinning. The engine kind of sounds like it running, just not in a strong way.
    If there is an obvious major mechanical issue - then I’ll stop researching Maxx Volts vs Prolong vs Lithium vs Sodium vs “buy a reconditioned hv battery off a guy of Facebook Marketplace” ;)
    Thanks again for the response - hope to get a method to get sub codes asap.
    #3 STL314, Dec 20, 2024
    51,011
    it doesn't sound right, but i can't identify it. maybe a bad clutch? idk
  5. Mendel Leisk
    40,457
    Presumably the EGR passages in the intake manifold as well? Also presumably the first EGR cleaning? That's very late in the day; my 2 cents: 50k miles (max) is optimum. I'd be checking the head gasket.
  6. STL314
    22
    St. Louis
    Hi Mendel,
    Yes the car was new to me - at around 170000. When EGR was cleaned it was definitely dirty and clogged, but there were signs that the cleaning had occurred at some point - I’m just not sure how long prior. Call me a lunatic, but I’ll consider cleaning again to see how much it can clog up again in 10000 miles or so.
    The hybrid battery is very low, so waiting for the grid charger to come and will wait for the battery to charge up before doing much more cranking.
    Cleaned the MAF again but it looked fine. Some oil pooled under the butterfly but nothing too crazy. Throttle body seems ok - will try a shot of starting fluid and crank to hopefully isolate to fuel delivery.
    Didn’t see a clear leak from the water pump, but have had an Asin pump on the shelf for awhile. Have a few days to wait on shipping so might swap it out if the engine hits easy on starting fluid.
    Happy New Years!
    #6 STL314, Dec 27, 2024
  7. STL314
    22
    St. Louis
    Just an update, the engine did hit briefly on starting fluid but after a few unhappy combustions it defaulted back to MG1 doing a 8-10 second cycle before stopping - no clunk this time thank goodness.
    Techstream freeze frame is showing a P0A0D-350 now - but it’s not the original P0A0F experienced, likely due to the troubleshooting starts.
    Waiting on the grid charger to arrive for hybrid battery reconditioning
    Did purchase the Acenbay copper bus bars from Amazon and replaced on the hybrid battery. The bus bars had moderate corrosion.
    Also did replace the 12v battery - the voltage of the battery connected in the car seems to drop overnight to 11.7 V after a trickle charge to 12.4V the previous day. Given many of the forum posts indicate a solution was changing the 12V - makes sense to factor this simple possibility out. It was a cold start after a week of sitting - maybe that’s it after all…
    Probably won’t do the water pump until isolating the battery stuff isn’t the source of the issue.
    #7 STL314, Dec 31, 2024
  8. ChapmanF
    17,180
    That's just "yo, somebody didn't click the battery service plug back in all the way."
    (Strictly speaking, there are also a couple cover safety interlocks on the inverter that can set the same code, but people much more seldom mess with those, so most times you see it, it's about the battery plug.)
    STL314 likes this.
  9. STL314
    22
    St. Louis
    Yep that makes sense - thanks!
    I reset codes after the couple of attempts - and as part the recent work had the orange plug out and did NOT slide the plug *fully* to the right after putting it back in.
    SOC is so low right now and ambient temp low enough that it’s best to wait for the grid charger to get SOC back up to something to remove that ghost from the shell of the work being done
    Thanks again for the feedback and response - adds up perfectly
  10. STL314
    22
    St. Louis
    Update: A winter storm delayed the shipment of the grid charger to get back to solving the problem. OEM battery so needed to be reconditioned anyway. Arrived yesterday and has charged overnight. Will let it soak through the day. Trying to decide if a discharge cycle or three is warranted given the situation.
    Posting to help keep the tread from locking. Know others experience and help will be needed if solving battery problems does not directly resolve.
    Mendel Leisk and Prodigyplace like this.
  11. Mendel Leisk
    40,457
    Threads never lock here.
    STL314 likes this.
  12. STL314
    22
    St. Louis
    UPDATE:
    12V Battery and HV battery charged - all good there. Cleared codes - got things back to square.
    Cranked for the grins - no start - 8 seconds or so and then stopped, kind of expected that.
    Suspecting Fuel Pump, especially after reviewing multiple threads. Lifted off the back seat and accessed the top of the fuel tank. Ohms seemed to show a fail with my multimeter. A quick bump of the +/- blades for the fuel pump with 12v indicates no joy. Likely a bad fuel pump from initial review - will begin shopping around for the best option forward. Just the pump or the whole assembly - hmmn - big price difference but would prefer to not touch this again for a while.
    Preparing to follow:
    DIY: Fuel Pump Replacement (10-15 Prius) | PriusChat
    #12 STL314, Jan 18, 2025
  13. AzusaPrius
    AzusaPrius Senior Member
    2,137
    900
    @Mendel Leisk
    Actually threads do and can get locked.
    Ask me how I know, I have two of my own threads locked here and I also got another thread locked if I remember correctly.
    But they do not get locked for no reason.
    Maybe he meant something like "loosing tread"
    Anyway...I better stop before this does get locked.
  14. STL314
    22
    St. Louis
    UPDATE: 100% Fuel Pump was root cause.
    For those in the dead cold of winter with these symptoms like I was - don’t try to test the fuel pressure in the engine bay - I did not find it an easy thing to do. The cause of your issue may be any number of things - but by far the quickest thing to do is take the back seat off and test the fuel pump. That is after you make sure some wiring connections and the orange plug in the back are connected properly.
    It was exceptionally easy to take the rear seat off, pry the fuel cover off, and carefully disconnect the plug that connects to the fuel tank.
    From there a multimeter to test ohms between the two connector pins on the fuel tank side was pretty conclusive; however, a quick bump with 12v leaves no doubt.
    Be mindful you are near the fuel tank of course, but that was the clear indicator for me. The pump made no noise. Keep a fire extinguisher near by and take your time. I pushed my car out of the garage first….
    For the 2011, and I’m sure most gen3 Prius cars, the pin on the driver most side nearest the front of the car was the positive (red) connection to the fuel pump. Or the Bottom Right pin if you’re looking down from the top.
    the negative (black) pin was the one just to the left of it.
    I fretted over many things - would have slept better to just go straight to the fuel pump- probably would have been on the road within a couple of days if I just got the fuel pump immediately after determining it was bad.
    anyway - putting the interior back together and back on the road.
    ~$400ish for the traction battery grid charger - which I needed to do anyway - and $35 for a used fuel pump - plus some time and patience was all that was required.
    I did pickup a water pump for $150 because indications are that might be the next thing that fails - that or the head gasket of course.
    Thanks all for the help and feedback.
    P.S. - if you are in the St Louis area and need a battery recondition I’ve got a grid charger you can borrow just hit me up.
    Brian1954 and Mendel Leisk like this.
  15. Mendel Leisk
    40,457
    For me in Canada, see for a new one through Amayama, I'm looking at $900~ CDN, before shipping, likely about $50 more. Part no: 77020-47070. :cry:
    For forensics: had it since new, and are you prone to run the gas level low?
  16. STL314
    22
    St. Louis
    Youch! Yes that will leave a mark :)
    Most of the time I’d say the car stays between 1/3-3/4 full. Very rarely does it go all the way to empty unless just getting back from a longer trip.
    This car is used as a backup vehicle and for longer weekend trips - so it sits for an extended period often between use - but on average stays around 50% full of gas. The 12v battery did get weak - and it’s changed now. Also the hybrid battery was actually in pretty bad shape - we’ll see how the recondition helps it - probably will see some hydrid battery cell replacement in the future. I don’t know if that would have any negative effect on the fuel pump - but that thing was dead toast. 190,000+ honest good soldier miles with it though. Probably will give it an autopsy after the gas dries off. And then probably a bit of stress relief with use of a sledgehammer after wards. :)
  17. Grit
    Grit Senior Member
    6,411
    4,181
    Wilkes Land
    Drop the keys off to carvana while you still can.
  18. bbrages
    bbrages Member
    162
    47
    St. Louis
    Thank you for the update. It's so helpful when people with problems can post the fix.
    I am in the St Louis area, thanks for the offer! So far, my battery is hanging in there, but I might try to recondition it if I can figure out how. What model charger do you have?
  19. STL314
    22
    St. Louis
    Haha - maybe a good idea - backup vehicles are nice but the cost of insurance is real
  20. STL314
    22
    St. Louis
    At the time I thought I needed something fast - so researched Prolong and Maxx Volts. There was some debate in the forums over what to get between the two - so I basically decided what I thought would get to me quicker. To be fair - didn’t matter in the end - I think either is an ok choice.
    I bought a Maxx Volts unit - worked fine.
    DM me and we can work out the details - but yea it would be good for the device be put to use.
    #20 STL314, Feb 2, 2025
