Audio upgrade questions?
Discussion in 'Gen 3 Prius Audio and Electronics' started by ajc, Dec 16, 2009.
  1. ajc
    ajc Member
    340
    38
    pa
    I am thinking of replacing my III JBL audio system. I want to replace the HU, AMP and speakers with an aftermarket HU, AMP, speakers & sub.
    - will this void any warranties?
    - will this cause any problems with the 12V battery?
  2. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    It will only void a warranty if they can prove that your modification was at fault for whatever claim you're trying to make. That is the law. :)
    No, it will not cause any problems for your 12v battery unless you play the system for extended periods of time with the car off just as in a conventional vehicle.
    With a very high wattage system you may continually drain down the small stock 12v battery and it would be advisable to purchase and Optima deep-cycle battery that can better handle being drained regularly.
  3. ajc
    ajc Member
    340
    38
    pa
    Thanks for the reply.
    I will be installing a amp (4x125 RMS at 2oms) & a basslink sub (200 watts).
    Would I need to upgrade the battery?
  4. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    Depending on the brand and how you wire it up you may not see that much but even if you did I think you are fine. I ran my 1,500 Watt RMS amp for a couple years before I replaced my stock 12v battery.
  5. rrolff
    rrolff Prius Surgeon
    1,610
    246
    So Cal
    Someone else has done something similar (they kept the JBL amp) - I guess there is a wiring harness specific to the JBL system - i'd start with that...
  6. ajc
    ajc Member
    340
    38
    pa
    I was told that if I keep the factory HU I would have to use a cleansweep because I would not get a clean signal? Instead of spending the money for a cleansweep, replacing the HU is about the same $$ + I will get a direct signal - also the aftermarket HU is much better.
  7. ajc
    ajc Member
    340
    38
    pa
    I have the JBL system.
    Does anyone know what wire harness I will need to use for my aftermarket HU so I can retain the hot,ground and ignition?
