Auto-AC Button on Steering Wheel
Discussion in 'Gen 2 Prius Technical Discussion' started by anti-gas, Jul 29, 2008.
  1. anti-gas
    anti-gas Reduce, Reuse and Conserve
    56
    South Florida
    Ok, now I am hoping that someone has the correct answers to this.
    I noticed on my 2008 Prius, there is a button on the steering wheel that says, "Auto A/C". When I press this, the AC system comes on full bore. As I continue to drive, nothing changes. The owners manual says very little about this feature, what it is supposed to do and how it is supposed to work. What I want to know is the purpose of this button, and how it works and or what is it really supposed to do. My dealer can't tell me squat about it other than that is the Auto A/C function. If I push the button again, it shuts the system off.
    My thought was, that this would turn on the A/C system, and as the temperature drops in the car closer to your set point, it would reduce the fan speed, but that is my best guess and it clearly does not do that.
    My next question is if you set your A/C temperature control to 70 degrees vs. LO "lowest setting", do you save fuel at the 70 degree mark because the compressor works like a home A/C thermostat which shuts the compressor off when the temp reaches 70 and then back on if it goes above 70? Of by keeping it on 70, does the system turn the heat on to bring the temp, up so its not too cold in the car. From my preliminary tests, it seems to save me fuel consumption in the 70 degree mode, rather than the Lo mode. I want to be sure of this before I continue to operate in this fashion. I'm looking for that happy medium between comfort and fuel economy. I want to squeeze out every last penny from a gallon of petro.
    Thanks all.
  2. abq sfr
    abq sfr New Member
    690
    Albuquerque, NM
    The Auto-AC button should have really been named "Climate Control." You set a temp for it to maintain, and it uses the AC or Heat to get it to that temp, and it will act on high humidity conditions too. I worried about that too and almost drove myself nuts when I first got the car, dinking around with the individual settings. Now I simply dial in a temp and let the car worry about it and it works great. Yes, the more conservative you are with its use, the more mpg you will get. In the summer I usually set Auto to 80 around town, it keeps me and my wife comfy even if its high 90s outside. In FL I dont think you have a real winter. Basically the heat takes heat from the engine, which costs gas to bring back up. Also, initially I think there are some heating elements that take voltage from the traction battery before the gas engine is warmed up.
  3. Rest
    Rest Active Member
    1,210
    53
    CA
    Mine does this.
  4. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    70 is a little low for some of the cars out there. it's a defect of sorts... or so it seems so far. never recalled or anything on here.
    so.. there are a few on here. like me. who keep it around 80 in the mid summer to keep the battery from draining. others (seems to be the majority) say that they have no problem when it's about 100 out... set at 70 or less... so.. defect?
    If you have someone that you can compare to, or many... you may be able to get a dealer to lean your direction. never being rude, of course. :)
  5. Fraser
    Fraser New Member
    667
    Navarre, Florida
    Set the AC with the Climate window on the MFD. Then, whenever you want to enable or disable it, you have the option of pressing the Auto/AC button on the wheel. As your set temperature approaches the outside temperature, the fan slows down. If the set temperature is higher than the outside temperature, the produced airflow becomes warmer.
  6. V8Cobrakid
    3,790
    152
    btw.. there is a sensor on the dash. if light is pointing in through the windshield, the fans are turned up.
  7. KMO
    KMO Senior Member
    1,518
    395
    Finland
    2023 Prius Prime
    It does, as long as there is a set temperature. It doesn't if you set "MAX COLD" or "MAX HOT".
    Also, after selecting AUTO, you can override the fan speed or vent flows on the touchscreen, and you go into a "partial auto" mode - other functions remain on automatic, except for what you manually selected. Reselecting AUTO puts everything back to automatic. So if you touch a fan speed control after selecting AUTO, it won't change the fan speed.
  8. lefat1
    lefat1 Fat Member
    1,476
    47
    Sunny S. Florida
    i live in the same area as op, set mine at 76 and it does the rest all from the buttons on the steering wheel
  9. anti-gas
    56
    South Florida
    I will try it again today. I have always had the A/C system set to 70 degrees then pushed the auto button, but after an hour long drive, the car got nice and cool, but the fan speed never seemed to change at all, still blowing full bore.
    I have noticed that when I play with this feature, it somehow changes my Recirculate air setting to the fresh air setting letting in other car exhaust and humidity from outside.
    If I were to keep it on the 80 degree temperature and then use the auto feature, would it ever turn the heat on? How does it regulate tempurature, does it only cycle the compressor on/off or does it do something else to make it artificially warmer if the temp drops to far?
    Looking for the coolest temp in the car without using too much energy. Trying to find that happy medium. Thanks.
  10. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    To answer your second question, the A/C compressor on the Prius is even smarter than your one at home. Rather than using a simple on/off thermostat (bang-bang control), the Prius uses a proportional system. It runs the compressor faster if it needs more cooling, slower if it needs less.
    As for temperature setpoint, don't worry too much about what the numbers say. Depending on the sun and how I am dressed, and whether I need heat or cooling, some days I am fine with 78, other days I set it on 68. Use the temperature buttons on the steering wheel as comfort and fan adjusters: if you need it cooler drop the temperature a few clicks. It's that simple.
    Tom
  11. rigormortis
    rigormortis Active Member
    1,340
    26
    san jose, ca
    the more colder you set the auto a/c on the more the car will run on battery
    the more warmer you set the auto a/c on the more the car will run on the ICE
    sitting on my lunch break with the car in READY for 30 minutes and auto AC set
    to 72 causes the ICE to only be on for 5% of the time
    this is valid for toyota prius cars with the electrical a/c system thingy
  12. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    must be south florida... face it, at 70º, the fan may never adjust. here on the opposite end, it set mine at 68-75, (my comfort level varies, usually based on the amount of radiant heat, or sunshine...)
    the fan speed starts on high, but most of the time, it starts to kick down after less than 5 mins...
  13. bresna
    bresna Active Member
    193
    144
    Southern Maine
    In my experience, if it's hot outside and you have the temp any lower than 72, it stays in recirculate mode and the fan blows fairly fast all the time.
    I use 72 in the summer and 70 in the winter and it seems best for me.
  14. lefat1
    lefat1 Fat Member
    1,476
    47
    Sunny S. Florida
    has nothing to do with so florida, op is not understanding posts and thinks like i did with my rav4, turn a/c on and temp control to blue area. he only mentions 70 and 80 degree settings, i keep mine at 76-77 always and it does the rest, i put it to 70 after golf the other day and it stayed on too long as op stated, set it up a few degrees and all was well adjusting fan speed and cold air all by itself..amazing
  15. rigormortis
    1,340
    26
    san jose, ca
    the point i am trying to make is that the higher the temperature you have auto a/c set to the more likely your prius is going to burn more gasoline....
    if you care about fuel enonomy and want to keep the engine from kicking on you would set your a/c down from the upper 70s to the lower 70s, like 72
    based from my observatoins, the prius does not warm up the cabin from warm air outside, it warms it up like a regular car would, via its internal combustian engine
  16. ZippyPri
    ZippyPri New Member
    39
    Boston
    I am pretty sure I read somewhere in the manual that to get most efficiency out of using the A/C is to keep it at two degrees below the outside temperature. Now no matter how unrealistic this would be, especially if it is like 95 out, I think it helps to keep the windows open the first 5 mins of driving and then putting the A/C on at around 75. It is about 80-90 degrees during the day and it is plenty cool enough without much change in gas mileage.
  17. qbee42
    18,058
    3,074
    Northern Michigan
    This is misleading. The Prius uses heat from the ICE to warm the cabin when heat is required, and uses HV electricity to cool the cabin when A/C is required. Both of these conditions use energy, which ultimately came from burning gasoline. Best mileage will come from not needing to heat or cool. If you raise the temperature setpoint when cooling, the Prius will allow the cabin to warm by reducing the amount of cooling. The converse is true when heating in the winter.
    If you rapidly raise or lower the setpoint, it is possible the Prius may use heat or cooling to get there, rather than waiting for ambient conditions to do the job. This is because the Prius uses a proportional control system, either PI or PID, to control heating and cooling. Outside air temperature, humidity, cabin temperature, setpoint, and solar intensity are all used as control inputs and influence the decision of when and how much heating and cooling is needed.
    There are a couple of special cases that may be confusing you. Cabin air is used to cool the traction battery. If you allow the cabin to get too warm, it will interfere with operation of the traction battery. The other special case is max heat with a cold engine. There are two electric heating elements that come into play in this special case, thereby using HV electricity for heat.
    Other than that, your cabin temperature setting has nothing to do with fuel economy.
    Tom
  18. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    that would be wrong.
    let me restate that i have set AC as low as 68º and the fan speed still kicks down after a time...so it is either his AC is not functioning properly, or it has to do with his environment. i doubt the former is the case here.
    you say its because he sets it to 70º... well, maybe not the recommended setting, but in itself, the setting does not make the AC work improperly.
    now i would still recommend setting the temp higher since it would give instant feedback that the thermostat does work.
  19. doubleg2005
    doubleg2005 Member
    236
    set the temperature to whatever you like and when you feel comfy, turn the temp up until the fans slow down a little. it is possible to actually be cold in the prius when it's hot outside... on a long car trip, i set auto A/C at 73 and it started getting a little chilly since it was only about 80 outside that night so i raised the temp up to about 75 and it was very comfy.
  20. Sheepdog
    Sheepdog C'Mere Sheepie!
    1,125
    Sanford FLorida
    just set the thermostat for where you would like the temp to be.
    On auto-ac it will get it there as best it can with fast fan then slower fan when it gets closer. In FL just now the outside temps are near 100* for me so I set at 80* and let the car figure the rest out. 80* is surprisingly cool when it's triple digits outside!
