Auto Air Vents - Do They Work?
Discussion in 'Gen 2 Prius Main Forum' started by BexarWolf, May 27, 2007.
  1. BexarWolf
    BexarWolf New Member
    35
    I'm not sure if this is the right place to ask but.........
    Has anyone tried one of the solar powered auto air vents? They're the thing you roll up in your window and it circulates the air in the interior while you have the car parked.
    I've read some of the threads about heat damage in the Prius and with Central Texas summers coming up, I'm conisdering the options. I know a front window shade is in our near future but was just curious if anyone's tried the auto air vents.
    Shown here:
    http://nbchand.en.alibaba.com/product/5004...o_Air_Vent.html
    Thanks in advance.
  2. Tideland Prius
    16,445
    I believe there is a thread or two on it. If I remember correctly, our members have rather negative things to say about it.
  3. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    The main thing you definitely want is one of the windshield shades,
    the largest size you can get, because of that HUGE surface area and
    all that nice absorbent black dash underneath it. That alone will
    make the biggest difference, as long as you're not lazy about using
    the thing. If you're not too worried about rain or vandalism, leaving
    the side windows cracked half an inch helps too.
    The clamp-into-window fan units are cheezily built, and in the Prius
    won't seal the slot because there's an angled-down part of the
    opening in the front *and* rear windows. You'd have to kludge foam
    or something into there every time you set it up.
    I'm working on a quick-n-dirty project to power up the car's regular
    climate-control fan at a very low speed, without powering on the rest
    of the car, which is able to at least push some air through the
    cabin instead of letting it sit stagnant in there and keep heating
    up. It draws an amp or less from the 12V battery, which should be
    safe for several hours and if you have one of those solar-panel
    battery maintainers, that could help balance that out.
    The vent control has to be on "fresh air" position for that to work,
    of course, in conflict with leaving it in "recirc" position to try
    and keep rodents out of the A/C ductwork... different rest states
    for different weather, I suppose.
    _H*
  4. pingman
    pingman New Member
    124
    <div class='quotetop'>QUOTE(BexarWolf @ May 26 2007, 11:47 PM) [snapback]450681[/snapback]</div>
    I heard our local news peeps tested and it did not work at all
  5. faith2walk
    faith2walk Upgraded again
    154
    Alpena, MI
    <div class='quotetop'>QUOTE(BexarWolf @ May 27 2007, 12:47 AM) [snapback]450681[/snapback]</div>
    Had a friend who bought one and threw it away after one week, said he couldn't notice the difference...he had tried it on two cars, but the one that had tinted windows wouldn't work. I guess it couldn't get enough light to power the fan.
    After his recommendation I decided against it.
  6. lenjack
    lenjack Active Member
    804
    114
    Pennsylvania USA
    I've seen a few tests that indicated it made no difference at all, and one that said it RAISED the temp.
  7. BexarWolf
    35
    Thanks to all for the replies. I tried a search and I guess I'm still a newbie with the search feature. I think we'll pass on the auto fan, crack a window and go for the windshield shade. :)
  8. tochatihu
    tochatihu Senior Member
    9,548
    3,683
    Kunming Yunnan China
    2001 Prius
    I had a solar vent fan in the rear side window of a 2001 Prius for a while, and found that it was helpful in cooling the interior. However, it was very noisy on the highway and I could not be bothered to install/remove it each time. So now I leave the windows down a bit when the circumstances permit that.
  9. hobbit
    4,089
    468
    Bahstahn
