Auto button knocked inside dash...
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Badluckbilly, Dec 23, 2017.
  1. Badluckbilly
    Badluckbilly New Member
    nyc
    When entering the car my knee hit the auto button, located to the lower left of the steering wheel, in the most perfect way that it dislodged the button from the face plate and pushed it inside. The button seems to snap into the faceplate so I believe it's an easy fix of removing that dash portion and putting the button back in place. Can anyone provide instructions on how to safely remove that dash piece on a 2017 prius iv?
    picture of the recessed button:
    Loose Auto button | PriusChat
    If you can't tell from the picture the button is now just floating around in there.
  2. Elektroingenieur
    2,515
    3,258
    Three Touring
    See the Repair Manual, available by subscription to techinfo.toyota.com, under:
    • Vehicle Interior: Interior Panels/Trim: Lower Instrument Panel: Removal
      (Step 6 is “Remove Instrument Cluster Finish Panel Garnish Assembly.”)
    • Vehicle Exterior: Lighting (Ext): Automatic High Beam Main Switch: Removal
    In brief, grasp the top and bottom of the trim panel that surrounds the two groups of buttons—the instrument cluster finish panel garnish assembly, in Toyota’s terms—and pull it straight towards the rear of the car, disengaging four clips and a claw, and then disconnect the two electrical connectors. No tools should be required for this step; the garnish assembly just unsnaps. Next, use a small screwdriver to disengage the claws at both sides of the back of the No. 2 combination switch assembly that secure it to the garnish assembly.
    Parts catalog references:
    Figure 55-01, Instrument Panel & Glove Compartment:
    • Garnish Assembly, Instrument Cluster Finish Panel
      55470-47010 (with pre-collision system; list price $157.74)
    • Base, Switch Hole, No. 1
      55446-47150 (with pre-collision system; included in garnish assembly; list price $42.81)
    • Clip (quantity 4; red)
      90467-05172 (list price 80¢ each)
    Figure 84-01, Switch & Relay & Computer:
    • Switch Assembly, Combination No. 2
      84010-47250 (without HUD; list price $94.07)
      84010-47210 (with HUD; list price $133.00)
  3. Badluckbilly
    nyc
    It was as you said, no tools needed. Pulling with my hands removed the trim and then I simply snapped the auto button panel in. Was worried I'd have to do dismantling to get to that trim piece.
    Thanks so much for the help! Happy holidays.
  4. RCO
    RCO Senior Member
    3,709
    5,183
    Cornwall
    Welcome to Prius Chat. As you found, there's a wealth of useful information to be found from our members. Happy Holidays to you also.
    krmcg likes this.
  5. Robert Yang
    Robert Yang New Member
    Chicago
    Almost identical thing happened to me yesterday. I found this posting after a quick search!!
    I followed the same procedure by pulling the trim out with my hands (firmly pull but limit your pulling-out distance to no more than 4 inches to avoid damaging the the associated wires). Snapping the button panel back and pushing the trim back is a very easy task.
    5 minute job when you know what to do :)
    Thank you for the valuable postings!
  6. stri8ed
    stri8ed New Member
    2018 Prius
    Just wanted to thank you for this post. I bought a used prius with the buttons pushed in. Toyota dealership wanted to charge me $200 to "fix" this is o_O Following your instructions, I fixed it in 30 seconds.
  7. Kim Elmore
    Kim Elmore New Member
    Nomran, OK
    I'm a new member and want to thank you profusely for this post! I had the same problem: my auto high beam button got knocked into the dash. WIth the info here, it was *trivail* to fix. Literally maybe as much as 2 minutes from start to finish and I was done. Well done!
