Auto climate control
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Jim Fisk, Apr 19, 2015.
  1. Jim Fisk
    Jim Fisk New Member
    Phoenix
    When I press auto once it turns ON auto climate control. Why doesn't pressing the Auto button a second time turn AUTO off??
    #1 Jim Fisk, Apr 19, 2015
  2. StevoB
    StevoB New Member
    28
    2013 Prius Plug-in
    Pressing buttons other than Auto takes manual control. Fan speed, the "where does the air go" button, of course Off if you really want silence.
    I hate the way this stuff is set up, it makes no sense to me as an Old Person.
    Minor diversion: is there a way to use the fan without a temperature setting - in other words without ever engaging heat or AC? I really like plain old unadulterated highway air.
  3. Mendel Leisk
    41,889
    ^ At least on my Canadian model, if the AC button is not depressed (indicator light on the AC button off) AND the Mode button is not set to heat/defog, AC is off. I've monitored AC usage with my ScanGauge to confirm this. Oh, and you haven't pushed Front Heat/Defog.
  4. StevoB
    StevoB New Member
    28
    2013 Prius Plug-in
    Thanks, Mendel! I had been trying to match the temp setting to the outside temp, and I guess I don't have to!
  5. Mendel Leisk
    41,889
    I was misreading. I see "when is AC running?" and it's a flag to a bull, lol.
  6. fuzzy1
    10,602
    With AC off, have you set temperature to LO? On U.S. market units, LO is the next level below 65F.
    Unfortunately, this also corresponds to maximum AC when that gets toggled on. So in conditions when I'm occasionally bouncing between light AC use (temp setting 78-80F) and fresh air only without AC, the single toggle of the AC switch must be accompanied by many presses of the temperature setting buttons.
  7. ReDave
    ReDave Member
    82
    25
    Central California, Sierra/Sequoia Foothills
    2019 Prius Prime
    Agreed! i sort of hope that when its 78-80 outside, that when i have the temp set at 70 of so, that it is just blowing in unheated air.
    In many ways i really love the auto thermostat function, but my ocd side, does tend to push the temp setting to lo when just running the 'vent' [non-auto]
  8. AzWxGuy
    AzWxGuy Weather Guy
    1,065
    547
    Tucson, AZ
    2021 Prius
    I have noticed when it's in manual mode (AUTO light off) and I have the fan running for outside air that I still have to roll the temperature setting down at least to the outside air temperature reading. Otherwise there will be some heat added. I've also noticed that when I turn on the fan using the fan button the inside temperature setting always comes up on 75 degrees, no matter what the previous settings were when it was used last. That is different from how my Gen II functioned. It would remember what was set last.
