Auto-Dim Lights not working anymore
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Skewby, Aug 20, 2021.
  1. Skewby
    Skewby New Member
    Calgary
    2019 Prius
    Technology AWD-e
    For some reason, my auto-dim lights don’t work anymore. I can manually change the high beam and low beams, fog lights work, and so do DRLs. But at night the auto dimming function doesn’t work anymore. It doesn’t even light up with “auto” on the dash anymore.
    Ideas?
  2. Tideland Prius
    16,195
    Did you depress the auto-high beam button to the left of the steering wheel while the stalk is in the high beam position (and it’s dark outside)?
    #2 Tideland Prius, Aug 20, 2021
    Mendel Leisk, PtPri and alanclarkeau like this.
  3. Skewby
    Skewby New Member
    Calgary
    2019 Prius
    Technology AWD-e
    Holy. I swear I always forget that button… thanks!
    Tideland Prius likes this.
  4. Mendel Leisk
    38,875
    You do this once, and it’ll hold that setting?
  5. Tideland Prius
    16,195
    Yes as long as that button's light is illuminated.
    The green "AUTO" with the high beams symbol on the dashboard only illuminates when the system is active (i.e. in low light conditions). It won't show the during the day, even if the system is on so you have to check that the green light on the button is illuminated during the day.
    Mendel Leisk and dig4dirt like this.
