Auto-dimming mirror doesn't work?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by John75, May 9, 2015.
  1. John75
    John75 Junior Member
    25
    52
    Outside Philadelphia
    I hope someone will tell me that I'm just doing something wrong.
    Green light is lit, which to me means 'on.' Driving in the dark tonight, cars behind me blaring lights, and rearview mirror doesn't change at all.
    What am I doing wrong?
  2. Munpot42
    Munpot42 Senior Member
    1,391
    543
    Santa Monica, Ca. 90405
    My guess is that the rear sensor is being blocked by your rear spoiler, if true, I have no idea how to fix it.
  3. Mendel Leisk
    38,718
    If you switch it on/off, do you see any change to light intensity? We've got the same rear-view, and I'd pretty much forgotten the settings, happened to look it up a few months back, and yeah: light on means auto-dimming is (or should be) active.
    (Editorial, it should be "glare", not "blare", lol.)
    Oh, just reading now, I see everytime you turn the car off, then on, the mirror defaults to be auto-dimming on, or at least it should be:
  4. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    257
    Ocala, FL
    Still under warranty, right ?
    Have you had additional tint put on the back window ?
    I can't tell from the picture but a lot of center rearviews can be adjusted up or down by several inches by using the swivel AT the window mount point. As mentioned, maybe the mirror position is causing it to be "shaded" by the spoiler or by the back of the roof.
    Probably more likely that something actually needs to be fixed.
  5. RRxing
    RRxing Senior Member
    2,520
    1,791
    NEPA
    It works, just not very well. It's a known issue...
  6. Tinkerin
    Tinkerin Junior Member
    Seattle Washington
    Toyota needs to put the sensor on the top edge of the rear view mirror or at least allow the mirror to be rotated upside down - to get the sensor out of the shadow of the rear spoiler. The mirror is a part used by many cars in the US market.
  7. sosarahsays
    sosarahsays Member
    117
    37
    PNW
    Sometimes I find mine takes a minute after lights hit it to "turn"... As mentioned above, I guess maybe it has to be just the right angle.
    I wish the side view mirrors would dim, too. When a huge SUV or semi is driving behind me, the dimming rear view is little consolation when I am being blinded by light reflection off the side view!
