auto dimming mirror with home link on Prius Prime Premium??
Discussion in 'Prime Accessories and Modifications' started by Finn101, Jan 9, 2017.
  1. Finn101
    Finn101 New Member
    Has anyone successfully added an auto dimming mirrow with home link to the premium model??
  2. Tim R
    Tim R Member
    St. Louis, MO
    Exactly what I want to do. Was just looking on eBay for a mirror. Seems you can get them for < $50, so might be worth the project time.
  3. JC91006
    16,748
    8,554
    Or get a brand new one at the priuschat shop, on sale now
  4. Finn101
    Finn101 New Member
    i was told by several sources, including Dianne @ carson toyota, that due to the dynamic cruise control and collision detection hardware where the mirrior is located, it is at this point not possible to install a autodimming mirror.
  5. Tim R
    Tim R Member
    St. Louis, MO
    That doesn't make a huge amount of sense because these same features are in the Advanced model which has the HomeLink mirror. If the reason is because there is are missing power cables, that I'd believe.
  6. XnsmX
    XnsmX Junior Member
    Los Angeles
    An aftermarket mirror does not work and wiring is not the issue here. The mirrors we have has a base which extends out lower and longer, allowing it to clear the plastic cover on the windshield. Aftermarket mirrors can be mounted, however you have to leave the plastic cover off as it will push up against it, and you may or may not get the correct view depending on your height. You would have to buy an OEM Toyota mirror from the Advanced model. I think you may be able to get the Gen 4 Prius mirror to fit (P/N 87810-0WN90) but it's $500 and but I can't confirm it without having been in a Gen 4 before.
    Comparison of the Prime non-auto dimming mirror with aftermarket Gentex.
    I did a test fit before wiring anything. Mounted with cover off, I couldn't adjust it to get a correct view of the rear.
    Prius from Dad likes this.
  7. lx.josh
    lx.josh Junior Member
    34
    Los Angeles
    Same problem here. I just left the cover off. :/
    iPhone ?
  8. randomwalk101
    randomwalk101 DYI'er
    532
    271
    texas
    You may be able to just swap out the stock mirror's base to the aftermarket mirror. The aftermarket mirror (usually Gentex brand) is very easy to take apart (see link below). They swapped it but for a different reason. The stock mirror looks like you will have to bust the glass to get to it...but who cares, you're not going to use it again anyways. I have not taken the stock mirror base apart so not 100% sure but it looks like it can be done.
    Repair for vibrating, loose, wobbly auto dimming mirror - Taurus Car Club of America : Ford Taurus Forum
  9. XnsmX
    XnsmX Junior Member
    Los Angeles
    I would consider that or even cutting into the cover if i could, but regardless I couldn't get the right angle to view out the back.
    The aftermarket mirror had wiring that ran through the inside of the ball pivot joints and out the end of the base (this gives it a neat look with no exposed wiring) whereas the stock mirror was solid. I wouldn't be able to swap out the base without making a hole elsewhere to run the wiring out.
  10. randomwalk101
    532
    271
    texas
    Yeah some have wires run separately. In your case you will have to open that mirror up and drill a hole through the back and separate the wire out.
  11. jessetoedtman
    jessetoedtman Junior Member
    26
    San Diego
    I installed one a few weekends ago- used ATM Mini LP taps and had no problems, although the fuse box is so low profile, I wasnt able to get the cover back on- not a big deal. I routed the wiring behind the curtain airbags in the pillars.
    I bought a few on ebay to do friends cars but they backed out- If anyone wants one, $45 shipped they are yours. You can PM me here if interested.
  12. randomwalk101
    532
    271
    texas
    i cut up the stock mirror to see. It won't work. The base is totally different.
  13. Prime Example
    Prime Example Junior Member
    58
    99
    Shenandoah Valley
    Here is the part number for the auto-dimming mirror in the Advanced. It is expensive compared to the aftermarket versions - about $509 at discounted price. According to the website I found it on, the mirror also fits the Premium or Plus models. Is there a wiring harness in the Premium or Plus Prime that would make this "plug and play"? Here's the part: Mirror Inside - Toyota (87810-0WN90) I found the part on discountpartsmonster.com.
  14. lx.josh
    34
    Los Angeles
    Did you leave the small cover off or also the large cover which covers the camera module? I left the whole schbang off. IMG_5269.JPG
    iPhone ?
  15. Prime Example
    58
    99
    Shenandoah Valley
    lx.josh...is there a connector/harness to just plug-in the stock unit from the Advance model?
  16. lx.josh
    34
    Los Angeles
    There isn't. It was pretty much DIY. I ran power from the fuse box in the drivers footwell. GND, Constant 12V, and Switched 12V
    iPhone ?
  17. randomwalk101
    532
    271
    texas
    Wow. I don't know how you do it. It would have driven me nuts staring at those internals without a cover. :)
  18. luiset83
    luiset83 Member
    141
    78
    2023 Prius Prime
    XSE
    So the only feature missing from the Prime Premium that I had in my '04 is this mirror, and I really liked how it worked. The $500 price is a bit daunting, but being an EE by trade, I'm not a stranger to wiring, although it surprises me that there is not a built in harness. I'll see if I can subscribe to TIS and download the Wiring diagrams... years ago I did this for the 2004 Prius and compiled them into PDFs... not sure if that's still doable, but that would provide some idea of where they are tapping.
    If anyone else has done this recently, would be good to hear further comments :)
    HPrimeAdvanced likes this.
  19. HPrimeAdvanced
    HPrimeAdvanced Senior Member
    2,304
    3,519
    Anaheim, CA
    Mr. Luis, how do you test the so-called auto-dimming; the one in my Advanced doesn't seem to do anything. All I know is headlights of people behind me at night are too bright compared to performance of my old manually dimmed 2012 PIP inside rearview mirror. The inside rearview in Advanced has a "tint" which doesn't seem to change, day or night!
  20. luiset83
    luiset83 Member
    141
    78
    2023 Prius Prime
    XSE
    Easiest way for me is to shine your smarphone's LED flashlight onto the sensor in the front. Should pretty much dim instantly or in a few seconds. That's how I tested mine on the '04 a few weeks ago when I thought it was going bad. If it doesn't, probably it's not getting power and you'll want to test DC voltage to the connections with any multimeter.
    Also (perhaps obvious) make sure the on/off switch is on. Mine on the '04 had a green light to indicate the auto-dimming feature was on.
    Mark57 and HPrimeAdvanced like this.
