auto dimming mirror
Discussion in 'Gen 2 Prius Technical Discussion' started by lenjack, Oct 24, 2009.
  1. lenjack
    lenjack Active Member
    804
    114
    Pennsylvania USA
    Getting a Prius 3 on Friday. I'm installing a Gentex auto dimming mirror to replace the standard day-night mirror (I know the auto dim is standard on a Prius 4). Is there a conveniently located switched igntiion hot wire, near the mirror so I don't have to hunt around under the dash or fuses?
  2. spitinuri
    spitinuri Member
    317
    There should be map lights next to the sunglass holder.
  3. lenjack
    804
    114
    Pennsylvania USA
    Thanks. Anyone else?
  4. Tideland Prius
    16,142
    what spitinuri said. The personal light/maplight is the closest one.
  5. ceric
    ceric New Member
    1,114
    53
    Fremont, CA
    I think map light is constant 12V, not switched 12V, which can be found inside driver-side kick panel. For autodimming, you need switched 12V, not constant 12V.
    I installed a Homelink/Autodimming Gentax mirror myself on Mazda CX9. All three wires (ground, constant 12V, switched 12V) can be found there. Instructions from Mazda tells ones to connect there, not the map lights. There must be a reason for that. Current load?
    I don't have Prius wiring diagram, so I can't help you there.
  6. jonnyboy
    jonnyboy Junior Member
    Australia
    There is a switched 12v wire connected to the map light. It should be brown and goes to a corner pin (pin 7). If you have navigation, this is used by the mic. I just went to the car to test it, if you don't have nav, this wire is not connected.
  7. Duncan64
    Duncan64 New Member
    South Portland, Maine
    I would also like to install one of these in a 2007... How did it work out? Thanks!
