Auto-dimming rear view mirror
Discussion in 'Gen 2 Prius Main Forum' started by Doc Willie, Sep 4, 2007.
  1. Doc Willie
    1,717
    144
    Out there, somewhere
    I cannot tell if the auto-dimming reqr view mirror in the 2007 Prius is working. It does not seem all that dim at night compared with the manually dimmed mirrors in other cars. I don't feel like I am gettng blasted by the lights from following cars, but the light does not appear much darker than what is coming through the side mirrors, and I can see much more detail at night through the mirror than I can through other cars, where the headlights is about all I can see.
    How can one tell if it is working. The green light is on, indicating it is functioning.
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    Park your Prius at night so you can see lights in the mirror, then turn the mirror on and off. Give it a couple of seconds to respond.
    Tom
  3. ny biker
    ny biker Member
    463
    Northern Virginia
    2022 Prius
    I think it sounds like it is working - your description is similar to my experience. One thing is that it responds to light (i.e., headlights) shining into it, so if there are no cars behind you it won't dim.
    It does take some time to go into full dimming mode - I have never felt blinded by lights behind me because it wasn't dimming fast enough, but I have noticed it changing when there are steady lights behind me, such as when I'm driving at night on a highway with lots of cars all around. When it's really in full dimming mode, the headlights seem a bit greenish in the mirror.
    I actually think it is superior to regular manually-dimmed mirrors. My eyes are very sensitive to bright lights but I have no problems with reflected headlights and this mirror. I wish the side-view mirrors would dim automatically, too.
  4. Jeannie
    Jeannie Proud Prius Granny
    1,414
    Central New Jersey
    While driving on a busy multi-lane road after dark, notice how bright the headlights of following cars seem to be in your outside rear view mirrors compared to the auto-dimmed mirror, and then you'll be sure the auto-dimming feature is working.
  5. 9G-man
    9G-man Senior Member
    1,273
    194
    Atlanta, GA
    <div class='quotetop'>QUOTE(Doc Willie @ Sep 4 2007, 01:43 PM) [snapback]506829[/snapback]</div>
    Yeah, it's working. But if you want it to work even better (dim darker), just put a small piece of black electrical tape over the photo-eye that is on the side facing out the windshield. You'll like the results
  6. auricchio
    auricchio Member
    921
    Cambria, CA, USA
    I think the black tape is a bit of overkill, because it will cause the mirror to dim during the day. I leave my mirror on all the time...why bother turning it off?
    Try using a dark transparent film to cover the sensor. This fools the mirror into thinking it's darker outside, but it doesn't think the world is pitch black all the time.
  7. KD6HDX
    KD6HDX New Member
    256
    Chino Hills,CA
    I agree with Rick.
    At times mine does not seem to be working at all. But it is and sometimes it is slow to change. I always leave it on. Greenish hues have also been observed here.
  8. Tideland Prius
    16,211
    <div class='quotetop'>QUOTE(Doc Willie @ Sep 4 2007, 10:43 AM) [snapback]506829[/snapback]</div>
    It's working. The reason why it doesn't dim as much is because of the rear spoiler that blocks most of the light from the headlights of the car behind. As a result, sometimes you get the full headlight in the mirror and it's barely dimmed (cause the spoiler blocks the sensor).
    I would suggest rotating the mirror upside-down. Just be careful of the wires when you do so. After that, you'll see that it dims perfectly (and quite dark actually).
  9. aaf709
    3,862
    2022 Prius Prime
    <div class='quotetop'>QUOTE(Rick Auricchio @ Sep 4 2007, 03:14 PM) [snapback]506953[/snapback]</div>
    I don't have a problem with it, but I understand the black tape idea works best if it's only about 3/4 covered.
    From what I've heard, dark blue is best if you use transparent film.
  10. bobdavisnpf
    bobdavisnpf Member
    149
    I turned the mirror upside down without putting tape over the front sensor and it seems to be better. Does the front sensor get more "shade" in the upside-down position?
  11. Sarge
    Sarge Senior Member
    1,312
    767
    Milton, Ontario, Canada
    2023 Prius Prime
    XSE Premium
    To answer the OP's key question, the easiest way to just test if it is working is to just place your finger over the sensor on the back of the mirror (i.e. facing the windshield). Especially in daylight, it should dim very dark in seconds.
    Keep in mind that it uses the windshield-facing sensor to determine the ambient light and the one below the reflective surface to read the headlights behind you. If the ambient light is high, it will not dim no matter how much light is shining on the front (reflective) side of the mirror. In other words, you will not see as much dimming on a street with streetlights as you will when driving an unlit rural country road.
    As others have suggested partially or totally covering the sensor on the back of the mirror or flipping it upside down will generally make it dim more.
  12. Tideland Prius
    16,211
    <div class='quotetop'>QUOTE(bobdavisnpf @ Sep 5 2007, 09:52 AM) [snapback]507360[/snapback]</div>
    rather, more exposure to the light.
    The mirror has two sensors. One sensor is behind the mirror (facing the front of the car). That sensor detects ambient lighting conditions.
    The second sensor is in front of the mirror; the one you can see. Turning the mirror upside-down means that the headlights (or setting sun) can be detected by the mirror and hence the mirror can dim accordingly.
  13. Doc Willie
    1,717
    144
    <div class='quotetop'>QUOTE(Tideland Prius @ Sep 4 2007, 09:26 PM) [snapback]507040[/snapback]</div>
    I got to check it out last night, and it does indeed appear to be working. When dim, it just is not as dark as other mirrors, but the light coming through does not appear to be a problem. Maybe the color of the mirror tint is more efficient at keeping the "bad" light (whatever that may be) out while leaving more visibility. I may even get to prefer it, since I can actually see more than headlights out the back.
    If I rotate my mirror upside down, do I include that on my mod list? :lol:
  14. ElectricMayhem
    ElectricMayhem New Member
    I tried this, and it does make more sense from an optical standpoint (the shape of the upside-down mirror fits better w/ the shape of the rear window), but I found it did the opposite for the dimming.
    It seems to dim more when right-side-up.
    I can put my hand in front of the mirror when a car's behind me, and the light is more on the bottom than the top of the mirror.
