Auto Enginuity vs MG1
Discussion in 'Generation 1 Prius Discussion' started by bwilson4web, Apr 24, 2010.
  1. bwilson4web
    16,357
    Anytime you get a new instrument, the first steps should be to check the 'calibration.' A badly calibrated instrument has led many an engineer into a 'bad place.' So I was interested in seeing how well Auto Enginuity (AE) handles MG1 data.
    MG1 Torque - USELESS!
    This chart includes a test drive that includes numerous ICE off and similar conditions. But this is the distribution of AE MG1 (aka., generator) torque values:
    When the shifter is put in "N", there is no torque applied to the engine but this chart shows what appears to be a linear, signed value whose units make no sense. The Power Split Device (PSD) provides 28% counter torque to the engine. A value of either 500 or -500 Nm would imply an engine torque of 500/.28 ~= 1,756 Nm. Now I like our 1.5 L engine but it is NOT providing this much torque!!
    MG1 Current V - Possible
    This distribution of current values is consistent with "energy recirculate mode" (the left) and "normal mode" (the right.) Energy recirculate mode has also been called 'heretical mode' although the definition is a little murky:
    We still need a mapping of current to torque, NM, but the shape of the current graphs are consistent with the expected profile. However, I'm a little concerned about the maximum and minimum current values.
    MG1 Current W - Promising!
    This data looks much more consistent with the expected MG1 torque:
    We have both the positive and negative signs but more importantly, these values are consistent with expected ICE torque. Of the three values, this is the one that most makes sense to map to true MG1 torque, and engine ICE torque.
    Follow-Up
    I need to do a 'hill climb' test recording ICE rpm, MAF flow (seems to have reasonable values) and 'MG1 Current W'. Then I can compare the values to the Graham Miniscanner values. FYI, I have a dual-headed, DCL so I may (if there is no conflict on controller IDs) to record both. If so, a conversion function should be possible.
  2. w2co
    w2co Member
    366
    81
    Longmont, CO.
    Great job Bob,
    Yes I would have to agree with plot #3 the most, but #1 makes no sense at all. Hmmm
    Will have to try this one.
  3. bwilson4web
    16,357
    Here is another plot showing the absolute value of the two MG1 currents vs ICE rpm:
    Of the two, MG1 watt seems to be more consistent with the expected torque from the ICE. The MG1 current has too many outliers.
    What I need to do is record traction battery, MG1 and MG2 current and watt. In a steady state, the sum should be the vehicle overhead current plus some energy loss percentage. Most of the time, MG1 should be opposite sign and identical magnitude to MG2 current in steady state operation.
    BTW, the raw data record looks terribly inconsistent:
    Column 1 Column 2 Column 3 Column 4 Column 5 Column 6
    0 Time Engine (RPM) MG1 rpm MG1 Torque MG1 (A) MG1 W (A)
    1 09:49:01.711 0 0 0 0 0
    2 09:49:03.227 0 0 0 0 0
    3 09:49:04.742 0 0 0 0 0
    4 09:49:06.242 0 0 0 -0.49 0
    5 09:49:08.180 0 0 0 0 0
    6 09:49:09.680 0 -128 0 0 0
    7 09:49:11.180 0 -128 -116 0 0
    8 09:49:12.695 0 -256 -412 0 0
    9 09:49:14.227 0 1152 500.01 -0.49 50.75
    10 09:49:15.742 1696 2304 -372 5.37 -58.56
    11 09:49:17.242 2016 2560 -188 -68.32 70.76
    12 09:49:18.914 2336 2816 -496 -16.1 -75.64
    13 09:49:20.445 2496 2688 -412 71.74 74.66
    14 09:49:21.945 2432 2304 400 67.34 -58.56
    15 09:49:23.445 2208 1664 -352 66.37 -39.04
    16 09:49:24.945 2080 1536 296 50.75 -45.87
    17 09:49:26.445 2144 1280 -260 62.95 -33.67
    18 09:49:27.945 2144 1280 -252 60.02 63.44
    19 09:49:29.445 2144 1152 -404 0 23.91
    20 09:49:30.945 992 -2048 404 -64.42 6.34
    21 09:49:32.445 1184 256 -96 0.98 51.73
    Start of recorded data. Only the ICE rpm time-stamp is retained because the individual data time-stamps obscure data analysis.
    The MG1 rpm units are mislabeled "(Nm)" in the label " Generator - MG1 Revolution (Nm) [-16384 - 16383]". The values look right but the units are wrong. I've edited the column text to make sense, as much as is possible.
    We know MG1 spins up the ICE before it is started and we can see this 9:49:09 to 9:49:12. But where is the ICE rpm during the startup?
    MG1 Torque has already been shown to be useless. It is as if a random sampling of a counter were being captured and reported. The distribution of values has more in common with a random number generator than usable engineering data. Note that MG1 Torque appears to span a byte, a normal 'atomic' value. In contrast, the two MG1 current and watt values are single bytes.
    MG1 (A) and MG1 W (A) seem to have some association with expected values. The "0" value at 9:49:29 is something that seems to happen with Auto Enginuity. Data distribution suggests MG1 (A) has more outliers than MG1 W (A). Also, the sign of MG1 W (A) seems to flip somewhat randomly. The complete data distribution suggests sign flipping is a problem with both MG1 (A) and MG1 W (A).
    One follow up analysis will be to compare ICE, MG1, and MG2 rpm against the well know ratios Graham Davies reported:
    MG1 = (3.6 * ICE) - (2.6 * MG2)
    This will clearly show how trustable the Auto Enginuity data is for engineering analysis.
  4. w2co
    w2co Member
    366
    81
    Longmont, CO.
    Bob, Given the irregularities in live data, and the fact that MG1 also goes into charge mode regularly depending on conditions at the time, the data would be very hard to understand. Yes I agree a "steady state" record of realtime data would be in order. The best thing here would be a dyno. This would allow a steady accel or brake during the data capture, and would have to be strictly controlled as to when the record file was active. Also would have to remove all the obviously bogus points. But when capturing data while driving, it's hard to take all the bumps into perspective.
  5. bwilson4web
    16,357
    I've had the good luck to start with a Graham Miniscanner and that unit's data is solid. But this unit continues to disappoint. Not every data element but enough that I find it hard to trust it. For example, I found today that MG2 rpm increases by 128, which means the low order, six bits are not being read or reported.
    If you can, record MG2 rpm and see what the data looks like to you.
  6. w2co
    w2co Member
    366
    81
    Longmont, CO.
    Ok Bob sounds good for the next round of data here. I will have the car back again mid week, but plan on recording both MG1 rpm, A, W, Temp in one file, and then MG2 rpm, A, W, temp in another. I know there's some bugs and like you said AE is not very interested in the gen1 right now, so this is what we got I think for now anyway. But I still think it'll be good for when something does go bad in the car, at least I maybe won't have to pay the local dealer $100 to read the codes. I am doing all maintenance on this 03 myself now, but the 06 still goes in soon.
    Soon I will also induce an error and see if AE can read the dtc correctly, then correct the error and see if it can reset the codes ok. That will be important to me.
    Talk soon, Tom
  7. bwilson4web
    16,357
    I think we're seeing the same thing. For engineering data, AE is weak. We can probably map out the useful data and I'll keep AE informed of what we see. It doesn't mean they'll fix it but they can't fix what they don't know about.
