Auto headlights
Discussion in 'Prius v Technical Discussion' started by bonzork, May 13, 2016.
  1. bonzork
    bonzork New Member
    Connecticut
    Four Touring
    I have a 2012 prius v with the "auto" headlights setting. They turn on in the dark and turn off in the light. I have to remember to turn them on when it's raining. I wish that they worked like my previous 2009 prius, where they turned on when I started the car and turned off after I turned off the car and opened the door. Is there a way to get the new prius to act like the older ones headlight-wise?
  2. tommytrant20
    tommytrant20 New Member
    HCM
    2001 Prius
    Four Touring
    i thinks you should go guarantee or control by hand beause weather always chane can not dont use ic auto
  3. rjparker
    rjparker Tu Humilde Sirviente
    7,975
    4,716
    Texas Hill Country
    On my 2012 v3 I just leave the headlights in the ON position at all times. When I start up (Ready mode) they come on, when I shut down AND get out of the car they go off with the driver's side door closing. I believe there is a delay off parameter in the Display Audio system but I have mine at zero delay. My 08 works the same way. You can try it on yours, it might work, it might not since you have a v4.
    Synthetic and bonzork like this.
  4. Synthetic
    Synthetic Junior Member
    35
    El Paso
    Your comment helps as my spouse is the usual driver of our 2012 v Five. She tends to forget to turn on lights, so I set the lights stalk to AUTO, and apparently our setting-after-closing-driver-door must be at 30 seconds. However we had a sudden failure of of our 12V while on a trip and I wondered if that extra use contributed to the failure. And so we set the switch to off. Now that I know we can set the switch to no delay, I think we will try that. Thanks
  5. rjparker
    7,975
    4,716
    Texas Hill Country
    Your headlights don't actually run off the 12v battery when the car is in "ready" mode and capable of running. The inverter under the hood takes the HV battery down to 12v for all running tasks. Probably it was time for the 12v battery or there was an unintended discharge with the car off. The trunk light can do it with the door ajar as can the map lights if left on after shutdown. Even those discharges often respond to a jump and a subsequent recharge by the inverter of the 12v battery. It's happened a couple of times on my 2012 v and it still has the original 12v battery.
    #5 rjparker, Sep 18, 2016
  6. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    Any Owner with Display Audio or Navigation should be able to alter the delay on a 2012 v, as can the dealer. One oddity is that I recall even after 4 years, is that 30, 60, and 90 are listed but no delay is called off.
    It took awhile to convince my self I wanted off. (When I park in the dark, 95% of the time I am in my own garage, so no delay makes sense for me)
    http://www.toyota.com/t3Portal/document/om-s/OM47674U/pdf/OM47674U.pdf Page 525
  7. Brad High
    Brad High New Member
    Hawaii
    I installed a used Auto Headlight turn signal stalk IT WORKS. Yet there is some labor involved it is easy to remove the airbag and steering wheel. The most difficult part is removing the stalk off the column, still not bad. Once you have this completed your headlights will function automatically when sensing dark and light. You also now have the option to add driving lights too.
  8. ChapmanF
    15,614
