Auto Hedlight leveling, how does it work ?
Discussion in 'Gen 2 Prius Main Forum' started by hsnmz, Feb 4, 2013.
  1. hsnmz
    hsnmz Junior Member
    74
    Pakistan
    hi guys,
    I am new to the forum and to a Prius. Just bought a 2008 (imported it from japan) 10 days ago. It's a S10th anniversary edition. I was curious how does the auto headlight leveling work and what's it good for ? My car has HID so are there separate tubes for high and low beam ?
  2. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    Welcome to the forum & Congrats on ur new to u Prius.
    The HID headlight in the 08 gen2 Prii uses a D4R bulb for both the low & high beams. When u activate the high beam the reflector shield right in front of the bulb moves allowing more light to be released.
    The auto leveling has a sensor on The rear axle beam that detects the load in the rear. This signal is then sent to the headlight leveling module with in turn sends a signal to the headlight leveling motors on the back of the headlight.
    The purpose is to keep the beam from the light on the road & out of the eyes of the surrounding drivers when u have passengers or cargo in the rear causing the rear of the car to sit lower than the front.
  3. hsnmz
    hsnmz Junior Member
    74
    Pakistan
    thnks for the info. can the level be manually adjusted just like in conventional headlights
  4. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    Yes. U need a Philip head screw driver. At the rear of the headlight, u will se the leveling motor teeth. Just slip the Philip screwdriver in the teeth to man adjust the level.
    hsnmz likes this.
  5. hsnmz
    hsnmz Junior Member
    74
    Pakistan
    got it, thanks
  6. boomer57tux
    boomer57tux New Member
    After I changed the headlights on my Prius 2007 I noticed the lights were on the roofs or the trees...Does anybody knows how to adjust them? Does Prius 2007 have an automatic leveler? Can I adjust it by hand? where is the automatic leveler? where can I adjust them by hand?
  7. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    If u have HIDs then u have the auto leveling headlights. Look at the back of the headlight towards the bottom.....there u will find the leveling motor. They can be adjusted with a long Philip head screwdriver.
