Auto-Lock and -Unlock: Still Push Button to Release charger?
Discussion in 'Prime Plug-in Charging' started by mr88cet, May 6, 2017.
  1. mr88cet
    mr88cet Senior Member
    2,311
    1,334
    Austin, TX
    I did a quick search of the manual and didn't see the answer, but perhaps you folks know off the tops of your heads:
    If you use the Auto-Lock and -Unlock mode to unlock the charger cable when you're charged, can you still disconnect the charger on demand, even if it hadn't finished charging, by pressing the button in the charge-connector area with the smart key on your person?
    This on the Advanced trim level, I mean...
    iPhone ? Pro
  2. Piwacet
    Piwacet Junior Member
    36
    San Francisco
    That's the way it works on mine.
    mr88cet likes this.
  3. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    you still have to physically remove the connector from the port for it to stop charging.
    mr88cet likes this.
  4. mr88cet
    2,311
    1,334
    Austin, TX
    OK, thanks. Most likely I'll keep it in that mode.
    iPhone ? Pro
    priuscatprimeguy likes this.
  5. Tideland Prius
    16,159
    Yup.
    That smart lock/unlock button in the charger area works regardless of setting.
    mr88cet likes this.
