Auto lock doors?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Frank Perkins, Nov 19, 2012.
  1. Frank Perkins
    Frank Perkins Member
    129
    66
    Fairfield, Connecticut
    Sorry for all the questions. I tried to find this isn the manual and the forums but couldn't find a recent posting.
    Question: After I park my car and exit the vehicle... shouldn't the doors lock automatically after a certain time? I was assuming they were automatically unlocking when I got close to the car but now I just realized it was never locked! Am I missing something or do I have manually lock it every time?
  2. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    have you proven this by leaving your key fob out of connecting range?
  3. Frank Perkins
    129
    66
    I tried it twice and both times it was unlocked....
  4. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    BTW I always put my index finger on the door handle to lock the door to be safe:D
  5. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    I left it unlocked and ran into home for about 5 minutes. When I returned, the car was locked.
  6. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    I have had occasions where I don't use my finger to lock the door, then the next day I return to my car to open the door and the door opens but no beep or parking/brake light indication. Which tells me the door wasn't locked. But I haven't tested the theory of leaving my key fob in my 14 floor apartment to see if the door opens
    lensovet likes this.
  7. lensovet
    2,615
    496
    Burlington, NJ
    i have never heard of this functionality. automatically locking doors? actually sounds cool, but definitely doesn't work.
    the only automatic locking is when you drive the car. in the car settings, you can change whether this is triggered by you going above a certain speed or you switching out of park.
  8. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    should help.
    No, I've never heard of the doors automatically locking after you exit. You need to press/squeeze the ridges on the door handle. The doors should lock and you should hear beeps to confirm.
    No, they don't unlock automatically when you approach either. You need to touch the rear of the door handles.
    However, if you unlock the doors (via either buttons on the key fob or touching the rear of the door handles) and none of the doors is opened, after a certain timeout, the doors will automatically re-lock.
    rxlawdude and lensovet like this.
  9. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    thanks for the video, that clears things up:D
  10. Frank Perkins
    129
    66
    "If a door is not opened with approximately 60 seconds after the vehicle is unlocked, the security feature automatically locks the vehicle again"
    It should lock itself, right?
  11. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    you're kidding....right? I have to turn my head sideways?:cry:
    cwerdna and lensovet like this.
  12. lensovet
    2,615
    496
    Burlington, NJ
    yes, if you UNLOCK the car and then FAIL TO OPEN THE DOOR, it will automatically lock after 60 seconds.
    not if you unlock the car, drive around, turn it off, and then walk away.
  13. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    What the manual is saying is that if the doors are already locked, then you unlock them but do not open the door in 60 seconds they will relock. This is not why you want as auto door locks.
  14. cwerdna
    12,544
    2,124
    SF Bay Area, CA
    Yep. This is exactly the timeout I was talking about.
    And the walking away after driving around == having to open a door in the first place.
  15. Frank Perkins
    129
    66
    Ok. I wish it would just auto lock after the power is turned off, door is open and closed after X seconds.
  16. ronlprius2
    ronlprius2 Junior Member
    56
    San Francisco
    I seem to recall that if I unlock the car but don't open the door, the doors will relock automatically. I never recall the car locking itself after I actually get out of it.
    iPad ? HD
  17. cwerdna
    12,544
    2,124
    SF Bay Area, CA
    Yes, and that's a feature that we've pointed out here already.
  18. lensovet
    2,615
    496
    Burlington, NJ
    is there any car that does this? i can see this getting annoying for "normal" cars without SKS.
  19. SJ PiP
    SJ PiP Member
    190
    35
    maybe this is not engineered because it would lead to more lockouts if keys dropped out of pocket or if keys (in purse or bag) are left in car by accident?
  20. hill
    8,925
    The PriusChat store sells an easy to install mod that'll lock the doors once the Prius is in motion ... but locking after you exit? Our Lexus does that ... so it's likely you could mod the feature onto the Prius also.
