AUTO mode blows only warm air, but Defrost mode works....
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Minty_Prius, Jul 10, 2015.
  1. Minty_Prius
    Minty_Prius New Member
    Washington DC
    Hello,
    On a recent 500 mile trip, I noticed the AUTO mode no longer triggered the cooling to work in my 2011 Prius. When I press AUTO and set the temp to a low temperature or LO, I only get warm air blowing out of the system (the AC button is lit when this happens). However, when I select the "defrost" button, very cold air comes out and the cooling seems to be working as usual. I've searched for quite a while on this topic, and can't find any similar situation described. Does anyone know how to fix this? My first thought would be a blown fuse, but I don't know which one I would check for this issue.
    Thanks for any ideas or leads!
  2. Tim Bender
    Tim Bender Member
    134
    44
    One of the peculiar things about the A/C system (and you can confirm this with a scangauge or OBDII tool) is that the A/C compressor runs when defrost is on regardless of whether the A/C button is lit or not. I assume that you're getting cold air when you press the "Front" defrost button.
    Do you get cold air when you cycle the "mode" button to the defrost icon? IIRC that state also engages the A/C compressor.
    I have no idea how you're going to track down the problem but this might point you in a direction.
    Minty_Prius likes this.
  3. Minty_Prius
    Washington DC
    Hello Tim,
    Thanks for responding! Yes, I am getting cold air when I press the "front" defrost button. I also get cold air when I cycble the "mode" button to defrost. I don't get cold air out of the main front vents when I press AUTO. I think this tells me the compressor is working fine, but something is wrong with the control. If you or anyone knows of any fuse to change or any test I can perform, it will be appreciated. Thank you!
    51,155
    try turning everything off, then turn the fan on, then set the airflow to face, then press the a/c button.
    Tim Bender, AzWxGuy and CR94 like this.
  5. Minty_Prius
    Washington DC
    Bisco. That worked! Thank you!
  6. bisco
    51,155
    pleasure.
  7. Spooled
    Spooled Member
    142
    26
    Concord, CA
    Wth? why doent the ac blow when on?
  8. John Allen
    John Allen New Member
    Dallas TX
    This doesn’t work for me, any other suggestion?
  9. bisco
    51,155
    welcome!
    are you experiencing the exact same symptoms?
