Auto mode for heat & A/C question
Discussion in 'Gen 3 Prius Main Forum' started by 4rpr15, Oct 1, 2015.
  1. 4rpr15
    4rpr15 Senior Member
    1,056
    375
    WI
    Here in the Midwest its starting to get cold, very cold.... so the heat is getting cranked. Why doesn't Auto mode leave it on the heat setting when I leave and come back? It reverts it back to A/C.
    MotoG3 ?
    51,154
    is it warm in the car? i assume it's using a/c to bring the temp down to your setting.
  3. Tideland Prius
    16,445
    What's your temperature setting and what temperature range are you seeing outside?
  4. JTM2955
    JTM2955 Active Member
    475
    185
    Its supposed to work like that. If it kicks on the A/C, its getting input from the solar sensor on the dashboard. That sensor is a photovoltaic cell that tells the Auto AC to run the compressor for a bit. When the target temp is reached, the compressor is turned off. No big deal, usually when you turn on the defroster, the compressor is engaged to knock the humidity out of the air going to the windshield.
    I have seen condensation appear after the car sits outside and the temp changes. Thankfully, most systems do this for faster windshield clearing. Note: you should not leave this in the defrost position, it will use more fuel do to theengine running more often.
    WilDavis likes this.
  5. bisco
    51,154
    if it's freezing inside the car, condensation could freeze to the inside of your windshield, making visibility a health hazard.
    JTM2955 likes this.
  6. 4rpr15
    1,056
    375
    WI
    Not quite.
    MotoG3 ?
  7. 4rpr15
    1,056
    375
    WI
    76 is the setting. 55 outside.
    MotoG3 ?
  8. bisco
    51,154
    must be the condensation.
  9. 4rpr15
    1,056
    375
    WI
    Meaning the A/C will automatically shut off while I'm driving?
    MotoG3 ?
  10. 4rpr15
    1,056
    375
    WI
    There was no visible condensation.
    MotoG3 ?
  11. bisco
    51,154
    you may need to have the dealer take a look.
  12. 4rpr15
    1,056
    375
    WI
    The heat and A/C work fine when I set them manually. The A/C works great in auto mode, I guess the heat mode setting will take a bit to get used to in Auto mode.
    MotoG3 ?
  13. JTM2955
    475
    185
    I don't know how many times I have seen drivers with the frost on the INSIDE of the car.
    You should never use RECIRCULATION during the winter. Your warm humid air you breathe in and out cause a build up of humidity in the car's interior.
    If they would simply move the air lever to fresh their problem would be solved. You know you have a problem when you see these guys scrapping the inside of their windshield.
  14. bisco
    51,154
    good point. this is especially true in high humididity.
  15. 4rpr15
    1,056
    375
    WI
    I have never used that.
    MotoG3 ?
  16. JTM2955
    475
    185
    Yes or it will cycle so minimally it will be almost unnoticed. Indeed, unless you go to the A/C button and manually turn it off.
  17. WilDavis
    WilDavis Senior Member
    2,493
    2,154
    49
    Yup, I've noticed mine choosing the setting of the "recycle/no-recycle" vent depending on the wx conditions outside - I let it do its own thing, and it seems to manage pretty well without me poking my nose in! ;)
    4rpr15 likes this.
  18. 4rpr15
    1,056
    375
    WI
    So even in Auto Mode I will need to manually shut the A/C off? I would think it should do that on its own. I'll test it in the morning. My Prius is garage parked so I can't see it starting up with the A/C in the morning.
    MotoG3 ?
  19. 4rpr15
    1,056
    375
    WI
    So set the temp, press Auto mode and leave it?
    MotoG3 ?
  20. JTM2955
    475
    185
    Right, it does take some getting used to. Just set it to your comfortable temp and forgetaboutit.
    I have mine set at 71 practically all the time. If I get cold, I might raise it to 75. If my wife rides with me, she will raise it to but I turn it down after she loses her chill.
    Also, don't worry if you start your car and the Auto AC does not work immediately. It does sense when the coolant temp is high enough to not cause a cold draft of air. Nicely thought out.
    4rpr15 likes this.
