Auto-Off Headlight
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Tideland Prius, Oct 17, 2005.
  1. Tideland Prius
    16,445
    Does anyone know if it's possible that the headlight will turn off either after a set amount of time or if EITHER front door is open?
    I get out the passenger side sometimes if traffic is heavy (and also, it's fairly easy for me to hop out the right side anyway). The problem is, the light won't turn off unless the driver's door is open right?
    Anyone have any suggestions as to how I can modify this setting?
  2. Frank Hudon
    Frank Hudon Senior Member
    4,147
    I haven't tried it but make sure that the interior light switch is on the door setting.
  3. Tideland Prius
    16,445
    What's the interior light gotta do with headlights? lol. My interior dome lamps are always at DOOR.
  4. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    I've encountered the same bug with the Auto headlights. Note: Auto headlights are not available on U.S. market Prius cars.
    If you leave the switch on Auto and open the driver door, they go out. I once tried the passenger door and they do NOT turn off. Since I rarely have passengers, it's not that big of a deal.
    My local dealer claims the THHT can be used to customise Auto headlight settings, like at what light level the headlights turn on. I've been thinking of doing that as when I park in the underground parking the headlights are always turning on.
  5. Tideland Prius
    16,445
    Yes, the sensitivity is adjustable. I was just wondering if other features such as opening either front door will turn off the headlight are available.
  6. DanMan32
    DanMan32 Senior Member
    3,799
    27
    Tampa Bay, FL
    Nope. However, I think the car will beep at you. At least it will if you turn the lights on from off while the car is off and then open the door. Auto off only activates if you power off with lights still on then open door.
  7. Mystery Squid
    Mystery Squid Junior Member
    Yup.
    Oh, and taking off on Danman a bit, if your lights are on, and you decide to pull over and take a nap, when you power off, the lights WILL remain on, and will NOT timeout. As Dan mentioned, the door has to be opened.
  8. DanMan32
    3,799
    27
    Tampa Bay, FL
    I was thinking of that very post when I wrote my response.
    Oh, and they will time out eventually, just not the way you would want them to.
  9. galaxee
    galaxee mostly benevolent
    9,810
    468
    MD
    so... flip the light switch off. it's not that time consuming :)
  10. Tideland Prius
    16,445
    I forget :p
    Besides, our Camry's auto-off function is that it turns off after 15 seconds after the last door/trunk lid is closed or if you press the lock button on the fob twice.
    i.e, the auto-off function on the Prius really isn't helpful. It doesn't stay on to illuminate the path home or turn off after a set time (short of draining the battery).
  11. TidelandAZ
    TidelandAZ New Member
    62
    Arizona
    I'm glad you mentioned that. I had auto headlights in my 2001 Highlander, saw "Auto" lights in the Prius user manual, saw the sensor on the dash, and wondered... hmm.. why wouldn't my package 6 (which is the max package, of course..so one assumes it has it all) have auto headlights?
    Well, duh, I guess that's because I live in the US. Silly me!
    Seriously, thanks for the sanity confirmation.
  12. DanMan32
    3,799
    27
    Tampa Bay, FL
    That's not the ambient light sensor. That's the ambient solar heat sensor for the HVAC. The empty slot next to it is where the sensor would be.
  13. TidelandAZ
    62
    Arizona
    Thanks for the clarification Dan!
  14. DanMan32
    3,799
    27
    Tampa Bay, FL
    I have found out that the audiable alarm (beep/buzzer) to remind one of the headlights when the auto-off is not applicable only sounds with the driver door.
  15. Tideland Prius
    16,445
    Ok, the driver's door only cutoff switch/alarm is starting to get annoying lol.
  16. KTPhil
    KTPhil Active Member
    1,379
    "Oh, and they will time out eventually, just not the way you would want them to. "
    Reminds me of a joke a friend told me. His competitive buddy bragged about his auto-off lights: "My headlights turn themselves off after 5 minutes." His reply: "So do mine, but it takes about 9 hours."
  17. GeekyDragon
    GeekyDragon New Member
    93
    Santa Cruz, CA
    In theory you should be able to re-wire the passenger door sensor in with the driver side door sensor. Not the SKS sensor or button, just the door ajar sensor (in the jam). I don't have a wiring diagram but if someone else does they might be able to tell you where those wires run.
    --GD
  18. DanMan32
    3,799
    27
    Tampa Bay, FL
    You could theoretically do that, but there might be unexpected consequences with that, like SKS knowing the difference between a passenger removing the fob, versus the driver removing it.
    OK, on the driver J/B, the violet wire on pin 21 of connector 1D is the driver door courtesy switch, and the brown wire on pin 24 is the passenger courtesy switch.
    Word of caution though, the hybrid and immobilizer sections of the wiring diagram also reference the driver courtesy switch.
    Also found brake control, key reminder, window control and door lock.
