Auto on headlights?
Discussion in 'Gen 4 Prius Main Forum' started by Paradox77, Nov 2, 2020.
  1. Paradox77
    Paradox77 New Member
    2020 Prius
    LE AWD-e
    So just got the car ( 2020 Prius LE AWD-e ) and it seems there is no auto on headlights when its dark outside? I thought this feature is pretty basic and it comes in all newer cars nowadays. Can anyone confirm this feature does not exist in our cars?
  2. Tideland Prius
    16,616
    Correct. The LE has "Auto-Off" headlights. XLE and Limited and full automatic headlights
    alanclarkeau and Paradox77 like this.
  3. Paradox77
    2020 Prius
    LE AWD-e
    Thanks for the reply. I suppose this can be retrofitted with the auto on/off...?
  4. Tideland Prius
    16,616
    I'm not actually sure. @Elektroingenieur , is this something that's easily added?
    alanclarkeau likes this.
  5. Paradox77
    2020 Prius
    LE AWD-e
    It seems the headlight units are the same. It probably needs a control module and perhaps a sensor to sense ambient lighting.
  6. David9962000
    David9962000 Member
    141
    68
    2020 Prius
    It's one thing that's missing and I'm surprised it's not standard since the LE trim has many driving aid features. Maybe it's to make the limited trim special?
  7. Elektroingenieur
    2,515
    3,287
    Three Touring
    That’s difficult to say for sure. In the Repair Manual (more info), the diagram of the exterior lighting system shows that there is an automatic light control sensor and associated wiring that would have to be added, but the headlight switch is the same except for the “AUTO” (rather than “DRL”) label.
    The control is in the software on the main body ECU (multiplex network body ECU), and this is the tricky part: Toyota’s parts catalog and service publications don’t tell us whether there is any version of the main body ECU and its software that has the automatic light control feature and would also work properly, under normal and abnormal conditions, with the other ECUs and equipment on the LE AWD-e model.
    Tideland Prius and Paradox77 like this.
  8. Salamander_King
    Salamander_King Senior Member
    11,024
    8,970
    New England
    Just to point out, the OP has LE AWD-e model, not Prius Prime LE. Yeah, one thing I miss on my 2020 PP LE switched from 2017 PP Premium (which is now XLE) is this auto headlight-on feature. :(
  9. Diemaster
    Diemaster Active Member
    295
    262
    so. cal
    No Auto-On Headlights for you!
  10. Gokhan
    Gokhan Senior Member
    6,534
    2,608
    Paramount CA
    If I had the LE trim, I would leave the lights on day and night to be on the safe side because one night out of one thousand and one nights you forget to turn them on and then you get into an accident. In fact in Norway, the cars are required to have their lights on at all times, as the concept of day and night is ambiguous there.
    #10 Gokhan, Nov 3, 2020
  11. Paradox77
    2020 Prius
    LE AWD-e
    Problem with that is the infotainment screen lights is tied together. So if I keep the headlights on, the infotainment screen is dark as it thinks its night time. I would have to manually go into the settings to switch it whenever it is day time or night time. So it wouldn't be any different from me just doing it from the steering wheel stalk at that point.
  12. David9962000
    David9962000 Member
    141
    68
    2020 Prius
    I'm not sure in California weather it is necessary to have your lights on all the time. Are the headlights sealed? Or if one stops working in a few years, can you can open them and replace the needed part?
  13. Tideland Prius
    16,616
    Totally didn't see it. I just saw that it's in the Prime forum.
    Alright, I'll move it to the Gen 4.
    alanclarkeau and Salamander_King like this.
  14. RRxing
    RRxing Senior Member
    2,554
    1,828
    NEPA
    The light sensor on the dash has dual functions:
    - Auto headlight on/off for car so equipped
    - Part of the neural network for the climate control system
    krmcg likes this.
  15. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    How does auto-off work if you don't have auto-on ? :unsure:
    ImaRogers and alanclarkeau like this.
  16. jerrymildred
    jerrymildred Senior Member
    11,517
    14,157
    Tampa, FL
    My wife's 2017 trim two has this. As I recall, the lights turn themselves off some time after you turn off the car. But then to turn them back on, you have to manually turn them off and back on. Pretty silly, eh? (Edited to add the part about after turning off the car. Thanks, @Salamander_King.)
    #16 jerrymildred, Nov 4, 2020
    kithmo and Salamander_King like this.
  17. Salamander_King
    11,024
    8,970
    New England
    I though the auto off is only for the time after the car is shut off. Or does it actually auto off during daylight?
    ImaRogers and jerrymildred like this.
  18. jerrymildred
    11,517
    14,157
    Tampa, FL
    Just when the car shuts off. I didn't think to include that detail.
    Salamander_King likes this.
  19. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    I've had just about every sort.
    • Manual - yep, we've all had lots of them.
    • VW early '70s turned Headlights off - but left parkers/side lights on.
    • Renault I think it was did the same - but beeped if I opened the door to remind me they were on.
    • Several cars had beepers which ... umm beeped ... when the ignition was turned off.
    • And 2 which I had to turn the headlights ON - but turned them off automatically.
    • And PRIUS - which is AUTO ON & OFF. Though - I leave them on PARK/SIDE most of the time during the day, so have to remember to turn the headlights ON if it gets dark [*].
    [*] - I knew you'd ask why:eek:. It's because, for some dumb reason, the DAYLIGHT RUNNING LIGHTS only turn the FRONT lights on.
    But driving on the Motorway most of my driving, I think it's more important to have the REAR lights lit - and PRIUS has such cool rear lights - so I put the PARK/SIDE lights on. They work AUTOMATICALLY - turn off when I park, start automatically when I start-up again.
    jerrymildred likes this.
  20. CooCooCaChoo
    CooCooCaChoo Senior Member
    961
    542
    Cow-lee-fornia
    2023 Prius
    My 2017 Two Eco ... has auto headlights.
    When the auto headlights are turned on, they come on when dark and turn off when light, or just off when you turn off the car off.
    This behavior can be seen when going through a long tunnel. Headlights come on after entering the tunnel and off again after exiting the tunnel.
