auto power windows stopped working
Discussion in 'Gen 2 Prius Audio and Electronics' started by dennis1231, Jun 25, 2007.
  1. dennis1231
    dennis1231 New Member
    Over the weekend I disconnected the ground on the 12V battery while I was converting the power outlet under the stereo to always hot. Everything works fine, but now I find that the one-touch auto power window no longer works. The window still goes up and down, the auto feature just seems to be lost. Does anyone know how to fix this? Thanks.
  2. finman
    finman Senior Member
    1,287
    111
    Albany, OR
    2014 Nissan LEAF
    Try running the window all the way down (holding the switch down). Then run it all the way up (holding switch up). continue holding the switch up for a few seconds after the window is fully up. That should reset the auto feature.
    Nathaniel Thorne and Abdu_mka like this.
  3. priusFTW
    priusFTW Gen III JBL non Nav
    434
    White Mtns New Hampshire
    <div class='quotetop'>QUOTE(finman @ Jun 25 2007, 08:49 AM) [snapback]467539[/snapback]</div>
    Exactly. This is discussed in the owner's manual.
  4. qbee42
    qbee42 My other car is a boat
    18,058
    3,073
    Northern Michigan
    <div class='quotetop'>QUOTE(priusFTW @ Jun 25 2007, 11:08 AM) [snapback]467577[/snapback]</div>
    Read the manual all the way to the end, then flip back to the front, then hold it there for a few seconds. :lol:
    Tom
  5. dennis1231
    Thanks for the tip finman, that did the trick.
  6. ws309
    ws309 Junior Member
    22
    ventura
    on my 2008 prius every window stopped working except the drivers. what would cause this to happen?
  7. MJFrog
    MJFrog Active Member
    780
    266
    NE Oklahoma
    2018 Nissan LEAF
    If you mean that the controls at each of the passenger doors do not work, but the windows work from the driver's controls... There is a window lock button on the driver's controls that locks passenger controls depending on its setting.
    If they don't work from any set of controls, then maybe a fuse???
  8. ws309
    ws309 Junior Member
    22
    ventura
    right sorry for the vague description of my problem. the drivers door controls do not work for any window except the drivers . i've checked the fuses and even used my power supply for my laptop to run one of the windows up, so i am know the switch for that window works(at that door) i did not try the drivers door switch for that window. someone said it could be my ecm thank you for any help, advice, ideas etc...
  9. Rere1967
    Rere1967 Junior Member
    22
    Springfield, VA
    Awesome! I knew I could find the answer here! Thanks!
  10. Nathaniel Thorne
    Nathaniel Thorne New Member
    North Carolina
    I created an account over 15 years later to say thanks. This actually fixed the issue on my 2013 prius.
  11. CH1992
    CH1992 New Member
    kansas
    Iv has the same issue happen in the past. Thanks for the tips
