Auto Stop Start in non hybrid
Discussion in 'Toyota Hybrids and EVs' started by CamryDriver, Aug 22, 2019.
  1. CamryDriver
    CamryDriver Active Member
    541
    391
    Arkansas
    A coworker mentioned renting a Toyota Highlander (non-hybrid) with hybrid like auto-stop. He said it started back up almost as quickly as our hybrids.
    I've been trying to research this system and haven't come up with much in the way of technical specifics. They say that generally the battery and starter are beefed up and the engine is coated to withstand the extra stop-start cycles.
    The thing that seemed silly to me was the reported requirement of Zero MPH before stopping the engine. My old Civic Hybrid would kill the engine at 20 MPH and I discovered that killing it sooner saved a lot of fuel. I'm sure this 0 MPH business is a safety thing but requiring the vehicle to be completely stopped seriously limits the usefulness of the system.
    Of course the Camry Hybrid will kill the engine even at highway speeds saving a ton of fuel.
  2. alanclarkeau
    alanclarkeau Senior Member
    7,044
    7,584
    near Brisbane, Australia
    With starter motors - I know Mazda don't use a starter motor - they prime the engine with a fuel charge and in approx TDC, kick off with a hit of spark to fire it into life. There are other technologies in use, including mild-hybrid systems.
    Those which do use the starter motor, but the motor is different, with better brushes and bearings etc.
    I don't know of any which killed the engine before it was stopped. I've driven a few (though don't recall a Honda) - and they all stopped once the vehicle was stopped - and if it was almost stationary and you put your foot down, it just resumed without re-starting. Some cut or reduce the fuel flow while decelerating.
  3. CamryDriver
    541
    391
    Arkansas
    I thought I read that the Mazda starter-less system never made it into production. Cool idea anyhow.
    alanclarkeau likes this.
  4. alanclarkeau
    7,044
    7,584
    The car I test-drove in 2016 had it. It didn't work initially, but the sales-lady eventually remembered that the engine/gearbox have to be warmed up completely, so we drove it further, and yes, it worked fine. Not quite as smooth as a PRIUS.
    Mazda I-stop Explained - Idling Stop - Discover Your Mazda
  5. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    These have been in cars for 15+ years now... This is what GM called a "mild hybrid". Most of them are absolutely terrible. The most recent ones are much better than they used to be. But still extremely annoying to anyone who has ever driven a real hybrid.
  6. meeder
    meeder Active Member
    239
    161
    Doesburg, The Netherlands
    Here in Europe just about every car has a stop-start system.
    With most cars that have automatic transmissions it is activated when you are at a complete stop and leave your foot on the brake and when you lift your foot it starts again. They implement additional electric oilpumps if the gearbox is a traditional automatic gearbox to have oilpressure when the engine is off.
    With manual transmissions the system is activated when you are in neutral and take your foot of the clutch pedal. When you press the clutch it starts again.
    It is not as smooth as with hybrid vehicles since they start of on the electric motor so the engine has time to start and wake up.
    fuzzy1, noonm and alanclarkeau like this.
  7. Prodigyplace
    Prodigyplace Senior Member
    11,696
    11,318
    Central Virginia
    The truck I rented when I moved here about 3 years ago had an auto stop start Diesel engine. I believe the technology is required in some areas to reduce pollution from engine idling.
  8. bisco
    49,490
    never heard of it in toyota
  9. noonm
    noonm Senior Member
    575
    595
    2018 Prius Prime
    Seems like it now exists for some Toyota gassers:
  10. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    I'm for any cross-over, shared concept or idea that makes all vehicles more efficient.
    I would speculate the challenge is selling the idea. That is, I'm thinking the audience that would want or appreciate a stop/start technology being employed, ARE the hybrid audience, that are buying vehicles with this technology by default.
    Unless the gas mileage boost is significant, most of the full ICE gear heads I know, would be highly against just the concept that their vehicle was turning off, and on, at stops.
    But, I still think it's a good thing to see the attempt.
    Having owned a Hybrid myself?
    I wouldn't be adverse to that technology in a ICE vehicle I owned.
    But since we aren't dealing with the vetted HSD system, that includes electric motors at start up and low speed, I guess I would have some concern how a "regular" engine would hold up to the same stop/start stress that a Hybrid is so brilliantly engineered to handle.
  11. mpg_numbers_guy
    116
    64
    VA
    Was your Civic hybrid a manual car? If so, my Insight worked the same way before I deleted the hybrid system. Now I just key off to coast.
    CVTs and automatics aren't designed to drive with the engine off due to no transmission fluid being circulated. The Civic hybrid has no EV mode like the Prius, which circulates transmission fluid by the electric motor if I have my facts straight. Don't quote me on that.
    Non-hybrid automatics and CVTs don't have anything to circulate transmission fluid while the car is off, hence why they don't turn off until 0 mph.
  12. Tideland Prius
    16,155
    It depends on the manufacturer. Some, like Porsche, allow sailing mode (stealth mode for Prius owners) so the engine can start up again even if the car is in motion.
    The 0mph requirement does seem to limit its usefulness but maybe Toyota’s System is as sophisticated or Toyota doesn’t want to install the more expensive version from a supplier because the Highlander is more price sensitive than a Porsche.
  13. Trollbait
    11,560
    Start/stop systems are basic mild hybrids without regenerative braking. They are even called micro-hybrids by some.
    Many Fords and GMs now have these systems, including the F150 and the tiny diesel in the Equinox and Cruze. The 2017 Malibu we test drove had it. Some of the earliest ones available in the US were the latest Fusion when introduced, the Malibu after the first eAssist was dropped, and one of the Kias.
    We didn't get many though because their impact on the EPA test was generally very small. That Kia and Fusion may have had a 1mpg higher rating in the city than the model without it. Now just having these systems gives a bonus to CAFE values. Europe has had them for far longer.
    Some people that haven't driven a hybrid find these systems annoying.
    Newer systems will do the shut off while coasting.
    It made it to production, but not to here.
    Fuel-Saving Mazda i-Stop Stalled In U.S. Because Of EPA Tests
    The article is from 2011, so we might see it. The US does get their regenerative braking system. Together, the systems make a mild hybrid without a traction battery
    Depends on the transmission. Most have the fluid pump on the front end, driven by the engine. Some have it on the back end, where it is driven by the wheels. Then some are designed to be adequately lubricated by just fluid splashing. If a car can be flat towed, the transmission is being lubricated with the engine off.
    #13 Trollbait, Aug 22, 2019
  14. royrose
    royrose Senior Member
    1,389
    949
    Foot of Pikes Peak
    The 2019 Subaru Forester has start/stop. A friend has it and doesn't like it. It is not as seamless as a regular hybrid because it does use the starter motor to restart. He can turn it off but it is automatically re-engaged the next time he uses his vehicle. At the end of each drive it tells him how much money he saved (not much). He purposely uses "rolling stops" more than he used to to minimize engine stopping.
    I wouldn't call it a mild hybrid. Some previous Honda models were considered mild hybrids because the electric motor would assist the gas motor but couldn't power the vehicle by itself. Micro hybrid? To me, no electric power, no hybrid.
  15. Trollbait
    11,560
    I don't care for the term, but micro-hybrid is an accepted technical one for a car with an auto start/stop system. Add regenerative braking, and you have a mild hybrid.
    Assist hybrids are mild ones that do more than the bare minimum to be a mild system. I don't think there is an official, technical definition, because of the vagueness of the term assist. What makes one system an assist and one a mild? Is the division defined by the electric motors power or torque output, or the ratio of that to engines, or something else? Assist hybrid is more of a marketing term.
  16. CamryDriver
    541
    391
    Arkansas
    My old Civic Hybrid was indeed a MT version. Shutting the ICE off at 20MPH is better than zero but nothing compared to what the Camry Hybrid does automatically. I did manually kill the engine in the Civic to maximize ICE off time but this was a bit dangerous as the electric system was disabled for a couple seconds before it would come back on. The way the Camry Hybrid works is brilliant, comfortable and safe.
    I'd be tempted to disable the stop start system if it only worked at Zero MPH. Just not worth the trouble.
    That Mazda system is cool but it does seem to still rely on the starter. The compression helps but it does not work alone.
    I think at one time they thought the Mazda might start back up without the starter being used at all. I'll try to find the article...
    Engine Stop-Start Systems Explained - Tech. Dept. - Car and Driver
    Car and Driver is calling the starterless Mazda system SISS. i-stop is similar but i-stop uses the starter.
    #16 CamryDriver, Aug 22, 2019
    Trollbait likes this.
  17. mpg_numbers_guy
    116
    64
    VA
    IIRC the "silent start" on the Honda hybrids used about 5x the power that the conventional starter did.
    The Camry/Prius never actually shut off completely; you're still running on electricity that must be recuperated by burning gasoline. Unless you're braking, that is.
    I key on/off and bump start all the time in the Insight and haven't ever had a problem. As long as you do it on a straight you should be fine.
  18. Tideland Prius
    16,155
    Doesn’t the Mazda6 have the i-ELOOP system? It has a small li-ion battery and regens (mostly to power accessories). It does make a difference in the Canadian fuel consumption tests.
  19. Trollbait
    11,560
    Unless it changed, the i-Eloop system uses a supercapacitor. It also made an improvement on US tests. The package it was part of also included active grill shutters.
    It also spun up the engine to a faster speed so the starts inflicted less wear and tear.
    Or stopped, or gliding. Even when used, the battery is usually replenished when the engine is running in its efficient range.
  20. Mendel Leisk
    38,726
    Just editorial, not trying to be a smart you-know-what:
    Who are you addressing? I don't see anyone on my ignore list, you're not quoting anyone, and your's is use of "civic hybrid" (or "civic") on the page.
    Maybe the mod's deleted some posts??
    Prodigyplace and alanclarkeau like this.
