Auto temperature control
Discussion in 'Gen 2 Prius Fuel Economy' started by mrhode, May 8, 2008.
  1. mrhode
    mrhode New Member
    MN
    I have a 2007 Prius. When I select Auto for temperature control the AC always comes on. Why is this? I don't need AC in the cooler weather. I can turn AC off and the Auto control continues but it is a nuisance to always have to turn it off.
  2. Tideland Prius
    16,159
    Just because it's on, doesn't mean it's running. It just means that the automatic climate control may turn it on and off as it deems necessary to cool or dehumidify the car.
  3. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    Exactly. The A/C green light on the MFD just means the compressor is enabled, not necessarily running. Also, with the Prius, it's not a black or white issue: the compressor can be off, on, or anywhere in between. If the Prius needs a little bit of cooling, it runs the compressor just a little bit.
    Tom
  4. Ichiro
    Ichiro Member
    335
    SF
    This is good to know... I've been leaving the auto function off to avoid using A/C.
    Do most of you leave the auto 'on' and adjust the temperature set-point as needed?
  5. qbee42
    18,058
    3,074
    Northern Michigan
    I leave my climate control on auto and adjust the temperature as needed. On rare occasions I switch to manual for open window driving.
    Tom
  6. dwdean
    dwdean Member
    377
    South Florida
    Here it's the only way to fly. I really like having the auto feature on the AC, even in a very hot car, it cools off quickly and then goes into "maintenance mode", all without making the car really cold.
  7. briansabeans
    briansabeans New Member
    53
    San Francisco
    This might sound dumb, but is there any way to 100% stop air from coming in from my vents? It seems as though even if I have the AC off and the fan off, I still feel air coming through the vents at whatever temperature I had it set to previously.
    I'm disappointed if I'm can't stop air from coming in. My 97 Mustang had few redeeming qualities, but it allowed you total control of the air -- you could turn it off when you didn't want any, and nothing would come in. My girlfriend's 2000 Accord won't let you turn the air off, ever, you just have to shut your vents and get it down as low as possible. It seems like my Prius suffers the same odd fate. Why are newer cars giving you less control? Or am I missing something?
  8. qbee42
    18,058
    3,074
    Northern Michigan
    It's a dealer configurable option. By default, the Prius always brings in some air from the outside. Your dealer can switch the settings to turn off the outside air.
    Tom
  9. fed123
    fed123 Member
    119
    New Jersey
    2024 Prius Prime
    If I turn all the climate controls off and keep the the recirculate button on I will not get air from the vents.
