Auto window question
Discussion in 'Gen 2 Prius Accessories & Modifications' started by silvergenII, Nov 4, 2015.
  1. silvergenII
    silvergenII Junior Member
    72
    Syracuse
    Ok Prius gurus... Is there a difference between the Drivers window mechanism vs the other three Windows , or is it merely the switch that makes it Automatic? I'd like to have the front Passenger window also be automatic.
    iPhone ?
  2. MickyMatter
    MickyMatter Active Member
    260
    168
    Germany
    I'd like to know that too.
    Maybe this can help someone finding an answer: uploadfromtaptalk1449091424579.png
    51,140
    guessing, but i can't see why it would be anything but the switch.
  4. MickyMatter
    260
    168
    Germany
    I've found this too:
    uploadfromtaptalk1449095811633.png uploadfromtaptalk1449095817576.png uploadfromtaptalk1449095822751.png uploadfromtaptalk1449095828861.png
    IMHO it looks like the drivers window motor is not the same as the others. There seems to be more connections.
  5. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    751
    Delaware
    most likely a position sensor in the drivers window motor.
  6. silvergenII
    72
    Syracuse
    Hmm . Looks as if it is more than just the switch. well it isn't that critical. Thanks for sharing!
