Automaker tests show damage to older car engines from running on E15 ethanol
Discussion in 'Other Cars' started by cwerdna, May 23, 2012.
  1. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    Key points from above:
  2. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    And I remember all these same scare stories when unleaded petrol was introduced.
    If you have an older car, run in on normal unleaded. You have a car that can run on E15, then use E15 when you're able.
  3. Trollbait
    11,563
    That's fine advice as long as you have the choice.
