Automatic Car Wash Checklist
Discussion in 'Prime Main Forum (2017-2022)' started by schja01, Jun 23, 2018.
  1. schja01
    schja01 Senior Member
    1,844
    1,226
    Chicagoland
    2024 Prius
    Limited AWD-e
    I should have my '18 Prime Advanced this week (fingers firmly crossed).
    One BIG concern is car washes. Specifically the type where your car is pulled through ala Walter White's car wash. I prefer commercial washes as they do a better job of cleaning the undercarriages. Especially in winter as they do salt the roadways here in Chicagoland.
    We have a very popular one nearby but I still want to do everything I can to minimize the possibility of a mishap.
    Has anyone put together a "Pre Carwash" checklist?
    Things that come to mind are:
    1) Fold side mirrors in.
    2) Turn off rain sensing wipers.
    3) Temporarily disable collision detection? Is this necessary since it's only enabled at 7mph+ ?
    4) Traction Battery charged.
    5) Turn off accessories.
    Being a private pilot myself I think checklists are essential.
    Any insight appreciated.
    J
    #1 schja01, Jun 23, 2018
    pilotgrrl likes this.
  2. Mendel Leisk
    41,928
    Avoid the pull-through car washes. With the ones where the car is off/stationary, half your issues are gone.
    If at all possible, DIY car washing, in the driveway or wherever, is preferable. At least periodically; the automated car washes are superfluous, and you will tend to miss spotting the minor mishaps that a car accumulates.
    #2 Mendel Leisk, Jun 23, 2018
    schja01 likes this.
  3. RRxing
    RRxing Senior Member
    2,555
    1,828
    NEPA
    If it's a pull-through, make sure that your hybrid battery is at or near full charge, and turn off all accessories (radio, A/C, etc.) Good Luck.
    schja01 likes this.
  4. PT Guy
    PT Guy Senior Member
    1,085
    712
    Washington, the state
    1--yes
    2--yes
    All windows up.
    Transmission in neutral. You get to neutral one of two ways---push the shift lever sideways and hold it for a second or two. You'll see the N light up. Or, tap the shifter left twice to the neutral position. It'll shift to neutral, give you the N light, and a couple more dratted beeps.
    Don't worry about the charge nor the collision thing. Ignore the dratted beeps and let it pull you through. When it's time to exit just move the shifter left & down to D. It's easy. You're a pilot, so think of flying an Airbus where the computer won't let the pilot do much wrong. The system in our Primes does most things for us better than many can do for themselves. There are a couple of ways we can manually maximize things, but not many.
    If they have a place for it, park and wipe the door jams. The rear hatch gasket is not near the lip, so dirt & suds accumulates there.
    schja01 likes this.
  5. dubit
    dubit Senior Member
    850
    538
    23
    Indiana
    2016 Prius c
    I don't know if the Prime has the big rubber strip on the roof that runs along the driver & passenger sides from front to back, but those are notorious for coming out of track in automatic car washes on just about every car that has them. Make sure to run your fingers along them with pressure after the wash if the Prime has them. Also, if your brave, tack on some Gorilla glue to them to keep them in place. Worked for me.
  6. cdnbrit
    cdnbrit Junior Member
    57
    24
    Cambridge, Ontario
    2018 Prius Prime
    Upgrade
    I go through the same wash every week. It's a pull thru. Learned the first time with the prime that i needed to fold the mirrors in. But oddly enough today my prime scraped the guide on the underside when i entered the Guide part (the front wheels go into.) Just very so briefly.. i stopped and looked and it seemed fine. Strange part is that I've been through that wash about 5x and never had this issue. Although... I had a 48 pack of bottled water and a 200 load wash jug of Tide in the trunk. (Both heavy items) Could they have some how led to the underside of the car touching something that I've never touched prior?
    On a side note, thinking of cancelling my wash pass and using the Manual Wash bays with my own brush and bucket. Not cheaper but i think better for the car with those whizzing brushes.
    schja01 likes this.
  7. PT Guy
    1,085
    712
    Cdn, were your tires fully inflated? Could the guide have been awry in some way?
