automatic driver window not working properly
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by ofjbarah, Oct 21, 2015.
  1. ofjbarah
    ofjbarah New Member
    jordan
    2015 Prius c
    when i do double press on the driver window button it wont work as is to make it close or open automatically
    anybody knows why ??inspite the car is 2015 still brand new
  2. Sean Nelson
    Sean Nelson Active Member
    421
    182
    Vancouver, BC Canada
    On my 2012 Prius C you don't "double press" the button to get it to open or close automatically, you simply hold it for about half a second and release it.
  3. Tideland Prius
    16,155
    Toyota auto up/down windows don't require a double press. You just press all the way down or pull all the way up to engage the auto function. You'll feel a click in the switch.
    If you've recently had the 12V battery disconnected, you'll just have to normalize the power windows. The instructions are in the manual (can't remember which page numbers). Same goes for the one-touch operation of the moonroof (you'll have to normalize that too if the 12V battery was disconnected).
