automatic electric grill blocking
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Flying White Dutchman, Feb 3, 2008.
  1. Flying White Dutchman
    4,376
    313
  2. Doc Willie
    1,717
    144
    Out there, somewhere
    Big rig truckers already have such a device. They lool like a venetian blind in fron of the grill. You might check into these for some ideas about implementation.
  3. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    It would be a fairly simple task to tie it into the CAN bus, and have it open and close automatically as needed.
    Tom
  4. icarus
    icarus Senior Member
    4,884
    976
    earth
    I've suggested that some mechanical guru make one of these before.
    Transport trucks (and busses) have therostaticlly controlled shutters that open and close as needed. It would be a rather simple mod to make. It would be really cool if Toyota or some aftermarket maker would produce one that was plug and play. Many of us could cob one together, but in my case my wife wouldn't let me mess with her car with cobbed together pieces. If you get one made, post it here and perhaps someone can start producing them. I'll buy one right away. It would be simpler to make a flat panel that sits in front of the radiator, but would be more efficient to block the grill to keep the (cold) air out of the entire engine compartment.
    Icarus
  5. Flying White Dutchman
    4,376
    313
    and you can keep driving with the grill block installed because when the outside temp rises it automaticly go's open or by the push of a button
  6. birdsquared
    birdsquared New Member
    46
    Burnaby, B.C., Canada
    Has anyone heard any rumours of such a device being contemplated by Toyota - or one of the mod companies like BT Tech?
  7. KAR IDEA
    KAR IDEA Member
    465
    Lake Peekskill, NY USA
    Three Touring
    This is a great idea, and I bet it wouldn't be hard to make...I think I've found a new project!
  8. SureValla
    SureValla Member
    590
    Shelton, CT
    i think its the saturn vue (correct if im wrong) concept that blocks its grill automatically at highway speeds.
    this of course is to improve aerodynamics not thermodynamics
  9. Oddest_raindrop
    Oddest_raindrop New Member
    75
    wisconsin
    My idea for automation would be simple tie it into the fan for the radiator when it starts open the louvers. Shuts off Close them. No matter what temp or speed. The car is already telling you when to dump off heat.
  10. icarus
    4,884
    976
    earth
    It ought to trigger before the fans. If you wait until the fans trigger, you get a double whammy of cooling, making the shutters to close and the fans to shut off again, then cycle over again. If the shutters open ~10f before the fan trigger, then the fan wouldn't need to turn on at all,,,making a more even temp.
    Icarus
  11. HOV-LEGAL
    HOV-LEGAL 60+mpg/602mi tank b4 blink pip
    chantilly va
    put me on the list for one if someone builds it!
  12. Hybrid Effects
    Hybrid Effects Junior Member
    97
    Orlando, Fl.
    $24.95 AERO BRAKES included (Shipping Included)
    I would like for it to be easy but It might be:confused:
    I am hopefully going to have a product soon that you can modify to your own likings.
    hope fully it will provide a platform for better fuel mileage:eek:
    The platform part was real.
    How about a product cheap of course:mad: that will allow you to add your own vents and motors, step, servo, linear gear motor etc. Heck maybe you could add floor vents to it:cool:
    I like the ideas that come fourth from this room. I ordered some supplies today and will start work on prototype this weekend.
    Franklin
  13. patsparks
    10,664
    567
    Adelaide South Australia
    A pop up headlight mechanism would be perfect to operate a shutter. Powerful compact quick motor and gearing includes automatic limit switching too.
  14. Rokeby
    Rokeby Member
    3,033
    709
    75
    Ballamer, Merlin
  15. Flying White Dutchman
    4,376
    313
  16. hill
    8,640
    Go for it my friend !!
    Just make certain it's for the Gen III ;)
    After you get that task done, I'll send you the dimentions of our Lexus hybrid & you can fit it too :D
  17. Flying White Dutchman
    4,376
    313
    what dream did you wakeup from hahaha
  18. aminorjourney
    aminorjourney Mum to two prius!
    335
    27
    Bristol, UK
    This looks like a great project - I think it would work great alongside your PHEV mod, Flying!
  19. Flying White Dutchman
    4,376
    313
    yes
    got a full block now working fine and canview to read the temp. value's to make sure nothing gets to hot!
  20. icarus
    4,884
    976
    earth
    Electric door lock activator is a great idea. Controlled with a thermistor to trigger a relay at say 200f.
    I still hope someone makes a plug and play model!
    Icarus
