Automatic Hold Brake!?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by BigBear2010, Apr 27, 2015.
  1. BigBear2010
    BigBear2010 Member
    156
    65
    Is there any way to mod the Prius ECU to hold the brake then release when you step on gas pedal? It will help a lot in traffic jam. I drove a 2015 Mercedes C350 with that feature and really love it. But when I tried it on my 2010 Prius, it only holds 3s.
  2. fuzzy1
    10,167
    I seem to remember driving some earlier Subaru Outbacks (sponsored event cars) that also held until gas was applied. But the Gen3 Prius times out quickly, gas or not, and I haven't heard of a workaround.
  3. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    257
    Ocala, FL
    While not quite as convenient, N works; so does the parking brake.
    Those cars with an electric parking brake will auto-release with throttle.......but I don't think any of the Prii have that.
    49,430
    anything is possible.
  5. BigBear2010
    BigBear2010 Member
    156
    65
    But.. How!?
    Prii dont have that, but i think with sofware update or modification will work, but dont know how to hack the ecu :(
  6. bisco
    49,430
    you'd be the first afaik, so if you're not capable, i can't think of a way to pull it off.
  7. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    CPROAudio can spoof the speed sensor for the navigation controls, and the temperature sensor can be spoofed to bypass the warm up cycle, so maybe the timeout feature on the brake release can be overriden/spoofed as well?
  8. bisco
    49,430
    anything is possible. if you have the money, time and talent.;)
