Automatic power hatchback trunk
Discussion in 'Gen 3 Prius Accessories and Modifications' started by cupidchild, Apr 21, 2015.
  1. cupidchild
    cupidchild Junior Member
    89
    Denver
    Anyone have done modification to make their hatchback trunk to close automatically by adding power lift latch or some other modification?
  2. mrbigh
    3,686
    699
    Long Island, NY
    Usually the electrical actuators for this application are much thicker than the OEM shocks.
    I imagine that this type of mod will be much complex than a simple change over of parts.
    49,693
    i don't recall seeing this mod done here. iirc, someone else asked about it though.
  4. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    Saw this feature in action on a Ford product in the parking lot the other day. I have to admit, it looks nice, and would be convenient in a lot of situations.
    Might just become more and more expected and common on hatch-backs and SUV's.
    But with improvement comes the complication. I'm still young and healthy enough that opening and closing the hatch isn't a problem. And I sure think maintenance and replacement of simple struts a lot easier and potentially cheaper than any problems that might eventually manifest with an electric powered hatch.
    It's like a couple decades ago, Ford had these "Automatic" Seat Belts that ran on a track, and would automatically come back when the vehicle was started, and go forward when stopped.
    My mom had an Escort that had these belts. At first they seemed really neat. But after a year or two the motor on one burned out. The replacement and repair cost was ridiculous. Made you appreciate the "unbreakable" reliability of the old manual seat belts.
    So anyway, I think the power hatch is neat...but I'm OK at this point with just the regular struts and using "Arm Power" to open and close.
    This might change in upcoming years.
  5. Bob Comer
    Bob Comer Active Member
    708
    458
    South Carolina low country
    Arm power is just fine unless you're short like I am. In the fully up position, I can't even come close to reaching the hatch to close it. I basically use a hook on a stick to close the hatch, but my next car may just be a C-MAX if the Prius doesn't get a powered hatch in the next version. It really is kind of a pain and the only thing I don't like about my Prius.
  6. mrbigh
    3,686
    699
    Long Island, NY
    Step stool ????
  7. Bob Comer
    708
    458
    That would be even more embarrassing to use!
  8. xliderider
    xliderider Senior Member
    7,891
    3,125
    Honolulu, HI
    This would solve your problem, and save you money over trying to get automatic hatch functionality:
    Hatchback hitting garage door solution! | PriusChat
    No stick with hook required, and it may prevent your hatch hitting low ceilings and other things hanging down from the ceiling.
  9. Bob Comer
    708
    458
    It could, if the struts were the right length for my height, but I'm also not one that can do much mechanical work, I'd have to hire someone else to do it. One of these days maybe...
  10. xliderider
    7,891
    3,125
    Honolulu, HI
    Not complicated, just turning a wrench.
  11. mrbigh
    3,686
    699
    Long Island, NY
    Replacing the rear struts is not a big deal, you need only an small flat screwdriver to loosen a "C" clip in either end.
    You first replace one side, then the other assembly.
