Automatic setting for heater
Discussion in 'Prius v Main Forum' started by Joe Fisher, Dec 6, 2015.
  1. Joe Fisher
    Joe Fisher Junior Member
    44
    Kalispell, Montana
    2015 Prius v wagon
    Apologies in advance if this is the wrong forum, but I wasn't sure where else to put it.
    Is there any way, when you use Auto heat, to have it heat other than feet only? I'd rather it default to the high vents.
  2. Offline
    Offline Active Member
    646
    240
    Lenexa, Kansas
    No, automatic means automatic but of course you can override it to send the heat wherever you want it.
  3. rjparker
    rjparker Tu Humilde Sirviente
    10,953
    6,872
    Texas Hill Country
    When you override it and set a mode and temperature, it will stay that way even after you stop and restart.
  4. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    I press Auto, then push the knob left and set bilevel. It stays that way forever
  5. rdgrimes
    rdgrimes Senior Member
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    If you keep the car out of ECO mode, it will automatically use bi-level and a few other things. Though maybe not the way you'd like. It will also use combo defrost-floor when its cold and humid. Bottom line: what you want is not "auto" mode.
